EAGLE User Chat (English) how to connect pads
  • Subscribers 187 subscribers
  • Views 352 views
how to connect pads
Im building a top and bottom only layer pcb.  Im not making any connections between the top and bottom layer.  So do i still need vias for my pads?  I only want to trace the through hole pads on the bottom layer.  What is the right command to use to trace my pads on the bottom layer only?
  • Richard_H
    0 Richard_H over 14 years ago
    Am 03.11.2011 18:27, schrieb Willie Miner:
    A pad or a via is defined a drilling through the board with
    copper rings in the signal layers and it is plated-through.
    A via is used for changing the signal layer, a pad is part of the
    package definition (in case you a using through hole components).
    If you want to use the bottom layer only, you don't have to
    do something special. Simply draw the traces in bottom layer.
    Richard Hammerl
