EAGLE User Chat (English) Vertical thru-hole parts libraries?
  • Subscribers 189 subscribers
  • Views 1704 views
  • diode
  • library
  • thru-hole
mamikee
mamikee over 14 years ago
Hi!
I'm trying to save some space on a board by mounting parts vertically.  Specifically some 1N4007 diodes and similar packages.
I really don't see any vertical parts (resistors, etc) in the RLC libraries, can anyone point me to a good *LBR file?
Mike Berry, Colorado
    Before I got comfortable making up new library parts from scratch and
    even now I sometimes do this:  Create a new empty library.  Then
    expand the "Libraries" tree in the Control Panel and find the library
    and device that is similar to what you want to make.  Then drag and
    drop just that device (and its packages and symbols) to the new empty
    library.  Now, in that new library make whatever edits you want in the
    symbol, package, and device.  At this point it is a good idea to
    rename the things you edited.  You don't have to disconnect the items
    in the device to do this.  The device will automatically be updated to
    reflect the new names if you rename a package or symbol.
    Then what I do is save the new library as zz.lbr (to make it appear at
    the end of the list of Eagle libraries).  At this point I can open
    some other library (preferably a custom library for the project I am
    working on).  Then I drag and drop the new device from the temporary
    zz.lbr file into my custom library.
    Robert Scott
    Ypsilanti, Michigan
  • mpopovics
    0 mpopovics over 14 years ago
    ...or if you can't find, you can create any time, as it is very simple component. On this way you expertise the SW itself and the created footprint will be on your special need. Then you can link it with your schematic component as second (or third) option for footprint
    I recommend to create or collect your own library with your most common used parts.
    For me it was always the best solution until certain level of complexity
    Am 01.02.2012 16:00, schrieb Mike Berry:
    Hi!
    For your vertical diode look at the diode.lbr. In there go down to
    "Diode-" and expand that to find Diode-C1702-05 or maybe Diode-D-2.5.
    If you need different sizes you may use these examples to create your
    own devices.
    Joern Paschedag
    On 2/1/2012 10:00 AM, Mike Berry wrote:
    Hi!
    I think the part footprint you want actually is in the rcl.lbr.   Look
    at the parts with 'V' (maybe for vertical?) suffix (eg 0204V).
    Jim
    For a very quick and simple 'one-off' I replace the axial component with
    two pads.  Remove the device from the schematic and place two pads.  You
    can then space the pads and set the hole sizes to whatever you need.  This
    gets tedious for many components where you just have to knuckle under and
    learn how to create a new component.
    HTH
    Brian
