EAGLE User Chat (English) Do I need to solder pads on top when connected to wire on top layer?
  • Views 550 views
  • pad
  • top
  • layer
  • via
I am creating a two layer board, top and bottom layers. Some pads on the top are connected to signal wires. These pads will be covered with IC socket, which will make it hard to solder on top. Are pads by default, in this case, act as a via? Or do I need to tell Eagle to make them act like Vias?
Thanks.
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    Thanks Warren. That worked great.
    Louis Yassa wrote:
    I found this similar question here:
    http://www.element14.com/community/message/36601#36601/l/re-how-to-solder-a-2-layer-board-with-no-busses
    (/message/36601#36601/l/re-how-to-solder-a-2-layer-board-with-no-busses)
    I wonder if there is a way to tells Eagle to just not start a signal
    wire from a pad on the top? or is it possible to just remove the top
    pads from the PCB and have the auto-router work only wth pads on the
    bottom layer?
    Place a rectangle, the size of your board, in the tRestrict layer. The
    autorouter will keep away from it and so only attempt to route the Bottom
    layer.
    HTH
    Warren
    news.cadsoft.de
    I found this similar question here: http://www.element14.com/community/message/36601#36601/l/re-how-to-solder-a-2-layer-board-with-no-busses
    I wonder if there is a way to tells Eagle to just not start a signal wire from a pad on the top? or is it possible to just remove the top pads from the PCB and have the auto-router work only wth pads on the bottom layer?
