EAGLE User Chat (English) How to swap layers?
  • Views 3550 views
How to swap layers?
Hi I have a finished pcb but I have one problem with it. It only has two layers (top & bottom) but they are round the wrong way i.e. top layer should be bottom layer and vice versa. Is there an easy way to change this? It is because there is surface mount pads on the top when they should be on the bottom. Im a newbie so please have patience with me. Thanks...
  • eugeny
    0 eugeny over 6 years ago
    Had same problem, but in my case I needed to swap bottom and top traces of the part of PCB. I went to DRC, added Layer 2 "(1*2*16)", and swapped layers through this layer using Change... -> Group. After completed, removed layer 2.
    The hard way image
    all commands typed in the command line, except #4 ... 6:
    1) set used_layers all, enter
    2) group all, enter
    3) mirror, enter
    4) Ctrl + RMB (does the mirroring)
    5) F7 (move)
    6) Ctrl + RMB to move the origin of the group back to coordinate x=0, y=0
    Hint: maybe problems  arise if you are using the freeware version. The
    allowed area for placing & moving components is restricted to 1/2 Eurocard
    (80x100mm). Choose an appropriate starting point for moving.
    or try: mirror-board.ulp (ulp-folder)
    r
