EAGLE User Chat (English) Labeling PCB for assembly.
  • Views 448 views
I'm remaking a PCB design that needs to be assembled at the manufacturer.  I was given a on old PCB design on paper and have recreated it in Eagle.  Where I'm stuck at right now is not knowing how to properly label the PCB so that the assembler can know where each component goes.  I'm afraid if it's not labeled correctly, diodes will be assembled backwards or components will be soldered incorrectly.  This is the design so far.
http://i.imgur.com/BxBGY.png
It's a part for a 1960's Pontiac tachometer.
The current labeling is not too good for someone who's never seen this board, but that's what the old design had.
I skipped the schematic part of the PCB designing, assuming that since I already have the routing laid out I didn't need it.  Is this wrong?
    wrong?
    It's fine to design a board only when it is as simple as yours. You do loose
    ERC checking without a schematic but that does not matter here if it
    replicates the original design.
    You can have as much or little text on your board. Your text may be copper
    or screen print, as you wish. Just put it on the appropriate layer.
    What you need now is a picture that the assembler can use. Normally you
    would have created packages in the library where the shape of the diodes etc
    reveal their orientation.
    Without these packages, which I suspect is your case, you need to draw  them
    in one of the Documentation layers and provide that to the assembler along
    the listings of what the parts are.
    Alternatively if  you wish to have the board built by a PCB house, with
    silkscreen printing (usually white ) to depict the components then draw
    these in the tPlace layer
    This layer can be included in the documantation to the asembler .
    HTH
    Warren
    news.cadsoft.de
