EAGLE User Chat (English) MAX6971 sink driver schematic?
  • Subscribers 189 subscribers
  • Views 608 views
I'm building a custom led display, which is already prototyped with an Ardiuno and working that uses multiple Maxim MAX6971ANG+MAX6971ANG+ sink drivers.  Rather than trying to wire this mess myself, I decided to try building my own PCB.  Since I've been designing chips for nearly 20 years, learning Eagle hasn't been to difficult, surprisingly fun, and I've already have much of the schematic drawn.
The problem is that I can't find a schematic for the 6971.  Is there one available?  Am I missing it?  Do I need to draw one myself?
Thanks for your help.
  • robotonics
    0 robotonics over 14 years ago
    Hi Bob
    I am used to making new Eagle parts, if you need any help let me know...would be glad to be of some use! image
    David
    Hi Bob
    Not one available in the Eagle libraries but try the attached. It was a
    simple adaption from a MAX7219EWGMAX7219EWG which was in MAXIM.lbr
    As always when receiving a library item from another, verify the package
    dimensions are correct and the pin / pad relationship is correct before
    using it.
    HTH
    Warren
    If you find one you need to verify it is correct for your needs and
    matches the data sheet. It takes about the same amount time to make a
    symbol from scratch, find or make a package and then connect a device.
    The advice is any part you use should be copied into "your lib" after it
    is checked for correctness and  use it from there.
    Paul R.
