EAGLE User Chat (English) New lib part does not show up in schematic but board
  • Views 452 views
  • library
Hi
My first component went rather well regarding the package but the "symbol" does not show up when I try to place it. I can see it in the board but ofcourse I get an error there.
The part is a very small 4x3mm TL1015 tact SMD switch:
http://www.e-switch.com/product/tabid/96/productid/6/sename/tl1015-series-micro-miniature-tact-switch/default.aspx
A little help would be much appriciated. (advises also)
/hans
<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.2">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.05" unitdist="inch" unit="inch" style="lines" multiple="1" display="yes" altdistance="0.025" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<library>
<description>TL-1015 Tactile switch top actuated SMD mounted</description>
<packages>
<package name="TL-1015">
<smd name="1" x="-2.0513" y="0" dx="1.0541" dy="1.4986" layer="1" rot="R180"/>
<smd name="2" x="2.0513" y="0" dx="1.0541" dy="1.4986" layer="1" rot="R180"/>
<wire x1="-2" y1="1.5" x2="-1.6" y2="1.5" width="0.127" layer="51"/>
<wire x1="-1.6" y1="1.5" x2="1.6" y2="1.5" width="0.127" layer="51"/>
<wire x1="1.6" y1="1.5" x2="2" y2="1.5" width="0.127" layer="51"/>
<wire x1="2" y1="1.5" x2="2" y2="1.1" width="0.127" layer="51"/>
<wire x1="2" y1="-1.1" x2="2" y2="-1.5" width="0.127" layer="51"/>
<wire x1="2" y1="-1.5" x2="1.6" y2="-1.5" width="0.127" layer="51"/>
<wire x1="1.6" y1="-1.5" x2="-1.6" y2="-1.5" width="0.127" layer="51"/>
<wire x1="-1.6" y1="-1.5" x2="-2" y2="-1.5" width="0.127" layer="51"/>
<wire x1="-2" y1="-1.5" x2="-2" y2="-1.1" width="0.127" layer="51"/>
<wire x1="-2" y1="1.1" x2="-2" y2="1.5" width="0.127" layer="51"/>
<wire x1="1.3" y1="0.6" x2="1.3" y2="-0.6" width="0.127" layer="51"/>
<wire x1="-1.3" y1="-0.6" x2="-1.3" y2="0.6" width="0.127" layer="51"/>
<wire x1="-1.6" y1="-1.5" x2="-1.6" y2="-1.1" width="0.127" layer="51"/>
<wire x1="-1.6" y1="-1.1" x2="-2" y2="-1.1" width="0.127" layer="51"/>
<wire x1="1.6" y1="-1.5" x2="1.6" y2="-1.1" width="0.127" layer="51"/>
<wire x1="1.6" y1="-1.1" x2="2" y2="-1.1" width="0.127" layer="51"/>
<wire x1="2" y1="1.1" x2="1.6" y2="1.1" width="0.127" layer="51"/>
<wire x1="1.6" y1="1.1" x2="1.6" y2="1.5" width="0.127" layer="51"/>
<wire x1="-2" y1="1.1" x2="-1.6" y2="1.1" width="0.127" layer="51"/>
<wire x1="-1.6" y1="1.1" x2="-1.6" y2="1.5" width="0.127" layer="51"/>
<wire x1="-0.7" y1="0.6" x2="0.7" y2="0.6" width="0.127" layer="21" curve="-98.797411"/>
<wire x1="0.7" y1="-0.6" x2="-0.7" y2="-0.6" width="0.127" layer="21" curve="-98.797411"/>
<wire x1="-1.3" y1="0.6" x2="-0.7" y2="0.6" width="0.127" layer="21"/>
<wire x1="0.7" y1="0.6" x2="1.3" y2="0.6" width="0.127" layer="21"/>
<wire x1="-1.3" y1="-0.6" x2="-0.7" y2="-0.6" width="0.127" layer="21"/>
<wire x1="0.7" y1="-0.6" x2="1.3" y2="-0.6" width="0.127" layer="21"/>
<wire x1="-2" y1="1.1" x2="-2" y2="0.85" width="0.127" layer="21"/>
<wire x1="2" y1="1.1" x2="2" y2="0.85" width="0.127" layer="21"/>
<wire x1="-2" y1="-1.1" x2="-2" y2="-0.85" width="0.127" layer="21"/>
<wire x1="2" y1="-1.1" x2="2" y2="-0.85" width="0.127" layer="21"/>
</package>
</packages>
<symbols>
<symbol name="TL-1015">
<wire x1="-5.08" y1="0" x2="5.08" y2="5.08" width="0.254" layer="94"/>
<pin name="1" x="-10.16" y="0" length="middle"/>
<pin name="2" x="10.16" y="0" length="middle" rot="R180"/>
<text x="-7.62" y="2.54" size="1.27" layer="94">&gt;NAME</text>
</symbol>
</symbols>
<devicesets>
<deviceset name="TL-1015">
<gates>
<gate name="G$1" symbol="TL-1015" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    Thanks! "Connect" was the word - I found the button. I thought they connected automatically when they had the same number.
    Scanning the XML it looks as if you have not defined any "Connects" between
    the Symbol pins and the Package pads when you assembled the Device.
    HTH
    Warren
    news.cadsoft.de
