EAGLE User Chat (English) xml error when opening a schematic in 6.1 or 6.2 from a 5.11 file.
  • Answers 2 answers
  • Views 759 views
I'm getting an error opening an older schematic in V6.2.  Also tried in 6.1 with the same result.  I can still open it and use it in 5.11.0
An error occurred while parsing the intermediate XML file.
The XML file has been loaded into a text editor window as C:/Users/usera/Documents/!eagle/XYZorg.rpt.sch
Error: line 11652, column 125: redefinition of name '!OUTB' in tag
What gives and how can I resolve the problem?
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    Thanks, I had looked at the XML file and didn't see the issue.  Turns out it was !OUTA that was the 2nd pin.  But my fix was to delete the part in the schematic and save it in 5.11, open it in 6.2 and reinstall the part.  Thanks though.
    Hi Phil,
    Usually these popup when the V5 contains some abnormatlity which V5
    could tolerate but when V6 converts it to XML, the resulting XML file is
    corrupted and V6 bails. More often then not the error is minor and EAGLE
    helps you out by telling you exactly where the error is occuring.
    If you're feeling brave open the XML file in a text editor (like the
    popular Notepad++) and look at the referenced line. More than likely
    either a few lines before or a few lines after you will find a second
    instance of !OUTB, you can consolidate the two and that will fix it.
    The other option is to e-mail me the file and let me fix it. You can
    e-mail the file to support@cadsoftusa.com.
    hth,
    Jorge Garcia
    Cadsoft Support
