EAGLE User Chat (English) New to Eagle - Too Many Component Choices
  • Views 290 views
jsthomps
jsthomps over 13 years ago
I'm trying to get back into the electronics hobby after a 30 year hiatus. I was hoping to use Eagle to start simple and move up from there. Here is an example of my problem; I want to select a standard 5mm LED and I get 100's if not 1000's of choices. I search for 74xx00 chip and I get dozens of chips when all I want is a thru-hole DIP. I'm nowhere near exploring surface mount technology. Is there any way to filter surface mount compents and provide me just the simpler choices?
Scott
    Op Sun, 07 Oct 2012 17:57:46 +0200 schreef Scott Thompson
    <noreply-67497@element14.com>:
    Scott
    Hello Scott,
    In the search window (ADD from schematic) there is a box in the lowerhand
    corner you can 'untick' to not search for smd parts. But I get the
    impression that you go about it the wrong way. You don't search for a
    74xx00, you search for a 7400 or a 7474, so exact part numbers. Eagle will
    add that part to the schematic and place the corresponding footprint on
    the board. If I search for 7400 I get 3 choices: A DIN, EU or US schematic
    symbol and if I turn the SMD search off, each with only a DIP14 footprint.
    In the 'doc' directory of your Eagle installation is the manual and a
    tutorial. It will take some time to get to know Eagle but it is usually
    better to invest that time than to continue 'battling' with it. It isn't
    hard.
    Good luck with your rediscovered hobby!
    Richard
