EAGLE User Chat (English) EAGLE -- scan in written signature?
  • Views 616 views
  • eagle
  • pcb
  • lpkf
  • manufacture
First let me start off by saying I have no idea where to start off with this (or if it's even possible) but here goes:
We had a neat idea here in my lab. I'm the resident maker of PCBs, and we use EAGLE 6.3 to generate files in the Gerber format, which our in-house prototyper accepts and then (after calculating toolpaths and some other wizardry) the prototyper carries out the movements and out pops a nice milled and drilled PCB. I trust we're all on the same page here.
Now the question is: I author all kinds of PCBs, so why can't I leave my mark on it? Think Rembrandt on any one of his pieces. Is there any way anyone can figure I could:
1. Scan in my own signature
2. Translate it into a package of some sort in an EAGLE library
3. Add that "part" as it were to a layout
4. And leave my mark on my PCBs?
Any and all assistance is much appreciated. And for you, I give you this cat .gif: https://i.chzbgr.com/completestore/12/10/15/XzUCXuHmnkWKX3ssBUqdRA2.gif
    0 shabaz over 13 years ago in reply to e14 Contributor
    Hi, this may help. It allows you to have custom text, shapes, images.
    Jorge Garcia wrote on Mon, 15 October 2012 14:22
    Hi Michael,
    Use the import-bmp.ulp to import a bitmap image into your design. This
    is the only image format EAGLE can import. You can access the ULPs by
    typing run in the command line.
    You can import the logo into a package in the library and place it on
    your board whenever you want.
    Let me know if you have any other questions or concerns.
    It's not quite that easy.  The import-bmp.ulp will import small rectangles
    to approximate the image.  However, and the instructions are clear about
    this, it is not intended to be left that way.  If you are trying to get the
    image into silk screen this won't work as the dots are individual items
    that are generally filtered out during manufacturing.  The dots are
    intended to be a guide to use other primitives (lines, arcs, rectangles,
    circles, ...) in order to hand draw the same image.  To save some time
    consider using a polygon for more complex shapes, just make the width
    something small, but not zero, like 0.001".  Zero width polygons give you
    trouble in various places.
    Of course, the large amount of small dots work fine in a schematic though
    it does tend to make the file size very large.
    This can be done but it is tedious, especially if you want a few different
    sizes of the same image for different boards.  But I have done it on a few
    occasions with good results.
    It would be better if there was some sort of scalable vector import.  But
    I've never seen anything like that before.
    Cheers,
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    Hi Michael,
    Best Regards,
    Jorge Garcia
