EAGLE User Chat (English) PCB Layout tool is changing my through-hole pad size of my library part
  • Subscribers 189 subscribers
  • Views 435 views
  • pcb_header
joelcrouch
joelcrouch over 13 years ago
I built a 6-pin through-hole straight header component with a pitch of 1.27mm using a hole size of 0.70mm(0.028").  However, when I import it into PCB Layout tool, the tool resizes the pads around holes, and now I get clearance errors when I run DRC check.  The only way I found to get rid of clearance errors is to reduce hole size to 0.02", but now I get hole size error not to mention that part will probably not fit now.  How can I fix this problem?
Joel
  • joelcrouch
    0 joelcrouch over 13 years ago in reply to e14 Contributor
    Hey Richard,
    Nope.  I do not have pad size set to auto in LIbrary.  PCB Layout is just overriding the way I defined the part in the library.
    Joel
    Op Sun, 04 Nov 2012 16:34:50 +0100 schreef Joel Crouch
    <noreply-143196@element14.com>:
    Joel
    Hello Joel,
    The 'pads around the hole' are called restring (rest-ring) in Eagle speak.
    When building your part you probably defined the pad size as 'auto'. Now
    the Design Rules Check (DRC) modifies the restring according to the rules
    defined there.
    You could explicitely define your pad size in the library and you should
    probably read up on the DRC setting in the help, to see how they influence
    these parameters.
    HTH
    Richard
