EAGLE User Chat (English) PCB layout in a NON normal shape in Eagle
  • Views 603 views
Hi all,
just 2 questions:
1. How is it possible to modify the layout perimeter or the borders of a PCB? I have to make a PCB with a strange shape, absolutely not rectangular.
2. In a manufacturer's data sheet, there is a suggestion of how to make the layout of the PCB. I could import it as a jpg file, as the attached one. May I, in your opinion, use it to speed up the layout in Eagle or not? And, if yes, how?
Thank you very much in advance if somebody could help.
paperino204
    On 05/11/12 16:50, Milo Sefcek wrote:
    Hi all,
    just 2 questions:
    rectangular.
    Draw it. Use the "wire" tool and select layer 20 - Dimension. Then draw
    the shape you want. You can also edit the default perimeter with a
    combination of "move" and "split" operations, but it's often easier to
    start from scratch.
    Something I've also done occasionally is to define a library part for a
    housing, if I know I'm using an off-the-shelf enclosure. I put a box
    icon as the schematic symbol, and the package consists of the
    recommended PCB shape and size drawn in layer 20. Then whenever I'm
    designing something to go in that type of box I add that component to
    the project and get my PCB outline and documentation of the housing,
    which also means it's included in the BoM.
    I suppose you could turn it into a BMP, use the import-bmp.ulp to put it
    down as background, then place the components and route the tracks using
    that background as template. The ULP imports into non-standard layers,
    so they won't propagate to the Gerber files and are easily excluded from
    printouts.
    HTH,
    Rob
