EAGLE User Chat (English) New to Eagle- "No Device Specified"
  • Replies 11 replies
  • Answers 2 answers
  • Subscribers 190 subscribers
  • Views 1860 views
japper
japper over 13 years ago
I am new to Eagle 6.3 and have board layed out and all errors have been fixed.
I am trying to make some Gerber files but need a little help....
With the board layout open, I click on the CAM icon and I enter a name and path for my file in the file box and then click process Job
but I must be missing something because I get an error rmessage that tells me "No Device Specified"
What am I missing or doing wrong?
thanks
    0 e14 Contributor over 13 years ago in reply to dukepro
    On 11/30/2012 5:15 PM, Chuck Huber wrote:
    The attached ULP, fixdrills.ulp, will round every via to the nearest
    mil.  After running it, set your drill list again (see above), and run
    the CAM processor.
    Hi Chuck,
    Any chance you would willing to upload that ULP to www.cadsoftusa.com.
    This is a very handy ULP and I'm sure many EAGLE users would find it
    helpful.
    Thanks.
    Jorge Garcia
    Cadsoft Support
  • japper
    0 japper over 13 years ago in reply to e14 Contributor
    thanks!
    That fixed it!
    0 e14 Contributor over 13 years ago in reply to japper
    hi,
    you must specify a tolerance, eg +/- 2.5%
    r
  • japper
    0 japper over 13 years ago in reply to japper
    Chuck-
    Here is what the drill file has:
    Generated by EAGLE CAM Processor 6.3.0
    Drill Station Info File: C:/eagle/SnowFlake/Snowflake-ExcellonDrill.dri
    Date              : 12/1/2012 2:29:19 AM
    Drills            : C:/eagle/SnowFlake/snoflake.drl
    Device            : Excellon drill station
    Parameter settings:
    Tolerance Drill + :  0.00 %
    Tolerance Drill - :  0.00 %
    Rotate            : no
    Mirror            : no
    Optimize          : yes
    Auto fit          : no
    OffsetX           : 0inch
    OffsetY           : 0inch
    Layers            : Drills Holes
    Drill File Info:
    Data Mode         : Absolute
    Units             : 1/10000 Inch
    Missing Drills:
    -- Requested --
    Size       used
    0.1400inch     5
    0.0320inch    84
    0.0400inch    29
    0.1300inch     1
    0.0360inch     8
    Drills used:
    Code  Size       used
    T01   0.0276inch     3
    T04   0.0394inch     6
    Total number of drills: 9
    !!!!!!!!! DRILLS MISSING - NO DRILL FILE HAS BEEN PRODUCED!
  • japper
    Chuck-
    I spoke too soon...
    I ran the fixdrills.ulp, set my drill list again, and run the CAM processor,
    pointed it to the latest drill file, and I sget the following message when
    I try to process the job:
    I would attach the cam file but I am not sure how to attach files to this post...
    thanks
  • dukepro
    0 dukepro over 13 years ago in reply to japper
    On 11/30/2012 03:52 PM, japper wrote:
    Thanks Chuck. I will look over this ini file and learn from it.
    Almost there... I did point update the Cam file to point to  the .drl file I saved
    from the drillcfg but when processin the job I get the  the following message:
    Is this OK?
    From your board editor, click Options->Set->Drill->Set.  This sets the
    list of drills to use in your design to the sizes that are actually
    present in the board.  Then run the CAM processor again.
    Be advised that some of your vias may be in metric.  If you get any
    drill sizes that are fractions of a mil, these need to be changed to an
    even mil size.
    the CAM processor.
    Also, what sections did you comment out of the cam file?
    It was for the two inner layers.  The file I provided earlier was for a
    4-layer board.  To avoid confusion, I just commented out the two inner
    layers, but left their respective sections in tact further on down the
    file.  Look in the top of the file in the "[CAM Processor Job]" section.
    You'll see two sections that are commented out with a leading hash mark.
        Description="
    Your Job Description Here
    \nThis CAM job
    consists of twelve sections that generate data for a four layer board.
    \n"
        Section=NonPTHoles
        Section=Drill
        Section=TopScreen
        Section=TopPaste
        Section=TopCu
        Section=TopMask
        Section=BotScreen
        Section=BotPaste
        Section=BotCu
        Section=BotMask
        #Section=Inner2
        #Section=Inner15
    I also left the NonPTHoles in place as an example.  On some boards, we
    have to have certain holes non-plated.  This adds to the cost of the
    board since an extra drilling process may be required after the
    plate-through process, but in some cases it is necessary.  This section
    tells the board house which holes should NOT be plated.  Depending on
    the size of the hole, this may be combined with the milling step where
    each board is being cut out of a much larger panel.  Because I am not
    intimetly familiar with the criteria, I leave that decision to them,
    just as long as I get the desired results.
    For a garden-variety 2-layer board, you can most likely comment out or
    delete the NonPTHoles section.
    You should probably also change the job description to something more
    suitable to your project.
    I appreciate your expert help!
    Glad to be of assistance.
    Best regards,
        - Chuck
    fixdrills.ulp.zip
  • japper
    Is this OK?
  • dukepro
    On 11/30/2012 08:56 AM, japper wrote:
    Thanks Chuck-
    I am working through this but not sure if  I am doing this correctly
    or not… Here is what I have done so far:
    I used the drillcfg.ulp that created snowflake.dri which I then saved
    to my project directory (C:\My Documents\Eagle\Snowflake) but was not
    able to find the Rack" text field or the "Drill file" section of my
    CAM job. The help says that this is in the CAM main menu but doesn’t
    really say how to get to this menu…
    On the Eagle Cam processor window there are thumb tabs for each
    section marked with an “*” I have two of these…
    I see.  It appears that you have not loaded a cam job.  Try saving the
    attached file in your project directory, then in the cam processor click
    File->Open->Job and select this file.
    It's an ascii text file so you can edit it with notepad, vim, emacs, or
    any plain text editor of your choice.  It contains sections for a
    4-layer board, but I have commented out the two sections for the inner
    copper layer.
    Once you load this CAM job, click on the section titled "Drill".  In it,
    you will see the "Rack" field.  I have pre-populated it with
    Snowflake-RevA.drl.  Either change this value to the .drl file you saved
    from drillcfg, or save your drillcfg output to this file name.
    The first section Output device is set to GERBER_RS274X, File is
    set to C:\Program Files\Eagle-6.3.0/cam/Snowflake and contains the
    following layers: 1 Top, 16 Bottom, 17 Pads, 18 Vias, 19 Unrouted, 20
    Dimension, 21 tPlace, 22 bPlace, 23 tOrigins, 24 bOrigins, 25 tNames,
    26 bNames, 27 tValues, 28 bValues, 29 tStop, 30 bStop, 31 tCream, 32
    bCream, 33 tFinish, 34 bFinish, 35 tGlue, 36 bGlue, 37, tTest, 38
    bTest, 39 tKeepout, 40 bKeepout, 41 tRestrict, 42 bRestrict, 43
    vRestrict, 44 Drills, 45 Holes, 46 Milling, 47 Measures, 48 Document,
    49 Reference, 51 tDocu, 52 bDocu,  101 Patch_Top, 102 Vscore, 103
    tMap, 104 Name, 105 tPlate, 106 bPlate, 107 Crop, 116 Patch_BOT
    Yeah... This is way too much.  What you're looking for is one section
    per layer.  So you'll wind up with one for the top silkscreen, one for
    the top solder mask, one for the top copper, etc.
    I get a warning that states “More than 1 signal layer active and when
    I OK this window, it creates the following files:
    That's a reasonable warning.  It's trying to put all the signal layers
    in a single gerber file.
    This is where knowing a little bit of how the boards are fabricated will
    help.  Each gerber file (one per section) is used in different places in
    the fabrication process.  The first thing the board house will do is to
    drill holes in the copper-covered fiberglass core.  Then they'll plate
    these holes through to provide a connection from the top to the bottom
    layer through each hole.  This is where the Excellon drill file is used
    (.exc, I think).
    The third step is to etch away the unwanted copper on the top and bottom
    layers (two separate patterns requiring two separate gerber files.
    Then they'll apply a solder mask and remove areas that should not be
    covered with mask.  Again, since the top and bottom mask layers are
    different, two different gerber files are required.
    The last step is to apply a silkscreen to the top and optionally the
    bottom of the board.  Got it yet? Two different patterns require two
    different gerber files.
    All in all, you'll wind up with 6 or 7 different gerber files - one for
    each step in the fabrication process.
    Am I doing this correct?
    You're on the right track, but you need to break the layers up into
    different sections.
    If you examine the attached snowflake.cam with a text editor, you'll
    find that it appears very much like a .ini file.  The first section
    describes the job and what sections comprise the job.  Then each
    following section, delineated with the section name in square brackets,
    is section-specific information.
    A note of caution: I have commented out two of the sections in the job
    section.  Thus if you save this as-is from within the CAM processor, the
    sections commented out will not be included in the saved file.  It'd be
    a good idea to save the attached file for future reference.
    I thought that I might try to view these with GC-Viewer but it didn’t
    like any of these files…
    I believe gerbv has a Windows version.  Wouldn't swear to it, though.
    Also, what actually makes a complete set of Gerber files that a PCB
    manufacturer would need? Is this the gpi, dri and any other files?
    The board house does not need the .gpi or the .dri files.  I usually
    toss these.
    HTH,
        - Chuck
    snowflake.cam.zip
  • japper
    Thanks Chuck-
    I am working through this but not sure if  I am doing this correctly or not… Here is what I have done so far:
    I used the drillcfg.ulp that created snowflake.dri which I then saved to my project directory (C:\My Documents\Eagle\Snowflake) but was not able to find the Rack" text field or the "Drill file" section of my CAM job. The help says that this is in the CAM main menu but doesn’t really say how to get to this menu…
    On the Eagle Cam processor window there are thumb tabs for each section marked with an “*”
    The first section
    Output device is set to GERBER_RS274X, File is set to C:\Program Files\Eagle-6.3.0/cam/Snowflake and contains the following layers:
    1 Top, 16 Bottom, 17 Pads, 18 Vias, 19 Unrouted, 20 Dimension, 21 tPlace, 22 bPlace, 23 tOrigins, 24 bOrigins, 25 tNames, 26 bNames, 27 tValues, 28 bValues, 29 tStop, 30 bStop, 31 tCream, 32 bCream, 33 tFinish, 34 bFinish, 35 tGlue, 36 bGlue, 37, tTest, 38 bTest, 39 tKeepout, 40 bKeepout, 41 tRestrict, 42 bRestrict, 43 vRestrict, 44 Drills, 45 Holes, 46 Milling, 47 Measures, 48 Document, 49 Reference, 51 tDocu, 52 bDocu,  101 Patch_Top, 102 Vscore, 103 tMap, 104 Name, 105 tPlate, 106 bPlate, 107 Crop, 116 Patch_BOT
    The second section
    Output device is set to EXCELLON, File is set to C:\Program Files\Eagle-6.3.0/cam/Snowflake and contains the following layers:
    44 Drills, 45 Holes, 46 milling, 47 Measures
    I get a warning that states “More than 1 signal layer active and when I OK this window,
    C:\Program Files\Eagle-6.3.0/cam/Snowflake.gpi,
    C:\Program Files\Eagle-6.3.0/cam/Snowflake.dri,
    I thought that I might try to view these with GC-Viewer but it didn’t like any of these files…
    Also, what actually makes a complete set of Gerber files that a PCB manufacturer would need?
    Please advise and thanks again!
    In article <k98rsq$aqs$1@cheetah.cadsoft.de>, chuck.huber@dukepro.com
    says...
    On 11/29/2012 04:44 PM, japper wrote:
    The instructions for this suggest a serious amount of software
    development should be done on this part of the process ?
