EAGLE User Chat (English) run cam processor from a makefile
  • Subscribers 189 subscribers
  • Views 643 views
I've looked at discussions on this in the forums and can't find a straight answer.
I'm running eagle6.3 in Fedora 14.  I want to include a command in a makefile (which I assume you realize is just a normal shell command) that runs the cam processor using my cam job file based on dependencies (gerber/drill files older than board file).
Can that be done?  Without entering eagle and loading the job, loading the board and running it.  Some magic you pass to 'eagle -X ........'?
Robert
    I guess I can withdraw the question now, since I've got the answer.  This snippet out of my Makefile does the trick:
    CAMX = ecamx.tcl
    JOB := project.cam
    BOARD := project.brd
    GERBERS := $(shell $(CAMX) --files $(JOB) $(BOARD))
    $(GERBERS): $(JOB) $(BOARD)
              $(CAMX) $(JOB) $(BOARD)
    As far as I know, this is Linux only.  I made no attempt to make this cross-platform.
    https://community.element14.com/cfs-file/__key/communityserver-discussions-components-files/309/ecamx.tcl
    I think I'm most of the way there with a Tcl script I wrote this afternoon.  Given a job file testx.cam and a board file test.brd, I can do this:
    $ ./ecamx.tcl --sections testx
    Outline
    measures
    Component side (CS)
    Layer 2
    Layer 3
    Layer 14
    Layer 15
    Solder side (SS)
    CS Silk screen
    CS Cream
    CS Solder stop mask
    SS Silk Screen
    SS Cream
    SS Solder stop mask
    Drills
    $ ./ecamx.tcl --verbose --dry-run testx test
    job:      testx.cam
    board:    test.brd
    sections: ALL
    found Outline
    exec eagle -X -dGERBER_RS274X -otest.dim test.brd  20 49
    found measures
    exec eagle -X -dGERBER_RS274X -otest.mea test.brd  20 44 45 47 49
    found Component side (CS)
    exec eagle -X -dGERBER_RS274X -otest.cmp test.brd  1 17 18 20 49
    found Layer 2
    exec eagle -X -dGERBER_RS274X -otest.ly2 test.brd  2 17 18 20 49
    found Layer 3
    exec eagle -X -dGERBER_RS274X -otest.ly3 test.brd  3 17 18 20 49
    found Layer 14
    exec eagle -X -dGERBER_RS274X -otest.ly14 test.brd  14 17 18 20 49
    found Layer 15
    exec eagle -X -dGERBER_RS274X -otest.ly15 test.brd  15 17 18 20 49
    found Solder side (SS)
    exec eagle -X -dGERBER_RS274X -otest.sol test.brd  16 17 18 20 49
    found CS Silk screen
    exec eagle -X -dGERBER_RS274X -otest.plc test.brd  20 21 25 49
    found CS Cream
    exec eagle -X -dGERBER_RS274X -otest.crc test.brd  20 31 49
    found CS Solder stop mask
    exec eagle -X -dGERBER_RS274X -otest.stc test.brd  20 29 49
    found SS Silk Screen
    exec eagle -X -dGERBER_RS274X -otest.pls test.brd  20 22 26 49
    found SS Cream
    exec eagle -X -dGERBER_RS274X -otest.crs test.brd  20 32 49
    found SS Solder stop mask
    exec eagle -X -dGERBER_RS274X -otest.sts test.brd  20 30 49
    found Drills
    exec eagle -X -dEXCELLON -otest.drd test.brd  44 45
    This may be all I need, even though I'm ignoring a lot of the other data in the job file and I'm not expanding placeholders (which I don't use anyways).
    But I'm still open to better ideas image
    Robert
    0 e14 Contributor over 13 years ago in reply to AnalogNotes
    Any idea what goes in the <command> part of "eaglecon -C <command>" to process a cam job?
    Robert
  • AnalogNotes
    0 AnalogNotes over 13 years ago
    I haven't tried the Linux version myself yet, but on winders, you can give the command eaglecon -C <command> to accomplish this.  I think you just use the "eagle" command on Linux or OS X.
    In my version 5 manual, it's on page 289, section 10.3 "Options at a Glance"...
    Doug
