EAGLE User Chat (English) USB Cable Assembly
  • Subscribers 189 subscribers
  • Views 742 views
USB Cable Assembly
     I am building a USB to Serial adapter but I have hit a snag.  The design uses a USB cable assembly but I cannot locate one in the EAGLE library.  I am not sure if I simply overlooked it or if it doesn't exist in EAGLE's software (which I find difficult to believe).
    0 e14 Contributor over 13 years ago in reply to sqkybeaver
    Thank you the pin header worked perfectly.
  • sqkybeaver
    0 sqkybeaver over 13 years ago in reply to e14 Contributor
    just use a standard 5 or 6 pin 0.1" header. it is easy enough to copy one to your own library and edit the pin names to suit.
    I can find the usb connectors that you mount onto the board but I mean the connector where one end is the usb port and the other end are the four (or five if it is shielded) cables that connect to the board.  I just found out about this and I hope that it will work.  Apparently, I can simply use a cable port for the USB cable assembly and then specify to the manufacturer that it is a USB cable.  Does that sound right?
    do you mean a usb connector? or the whole thing?
