EAGLE User Chat (English) I Can't Get Rid of Extra Drill Files
  • Subscribers 187 subscribers
  • Views 801 views
  • eagle
  • blind
  • drd
  • vias
  • layers
joelcrouch
joelcrouch over 13 years ago
I have this problem with two PCB designs where I accidently set my layers up as ((1*2)+(15*16)) instead of (1+2+15+16) under Design Rules/Layers.
Instead of generating just one .drd file, it now generates 3 different ones (.drd.0102, .drd0116, .drd.1516) even though I set my layers back to (1+2+15+16).
I am using Eagle version 6.4.
    Your initial layer description provided for blind vias. Normally that would
    require three separate drilling operations and hence the three files. So if
    you managed to create some in your design, that may be what is causing more
    than one drill file to be created.
    You could run the statistics ULP on the board and see if there are vias
    other than those between layers 1 and 16
    HTH
    Warren
