EAGLE User Chat (English) Gnd plane restrictions
  • Subscribers 187 subscribers
  • Views 380 views
I'm new to Eagle Light, and really like it.
I would like to define a solid ground plane that accepts only gnd connections, and prevent the autorouter from placing any other signals or traces from cutting across it. How do I do that?
I used a polygon on the bottom layer and named it GND. When I run autorouter, it connects Gnd signals just fine from the Top layer; but it also draws other nets across the bottom layer.
Thank you for your help,
Steve
    0 autodeskguest over 13 years ago
    Steve
    http://www.element14.com/community/message/70966#70966/l/gnd-plane-restrictions
    Change the settings for the Autorouter:
    Switch off all Optimize passes, then
    in the Route tab:
    cfVia = 0    Vias are welcome
    mnVia = 1    Max. one via per connection
    mnSegments  =  2..3  Short tracks
    Select the GND signal only and start routing.
    Might help.
    Richard Hammerl
