EAGLE User Chat (English) Track capacitance calculator
  • Subscribers 190 subscribers
  • Views 1309 views
edsonbrusque
edsonbrusque over 13 years ago
Hello!
Eagle does have a very usefull ULP called "length-freq-ri.ulp" where it automatically calculates tracks length, resistances etc.
Now, it would be great if an ULP (or any other piece of software) could calculate capacitances between tracks. It would be a great tool to better pcb designs, specially when dealing with high-frequency.
I know real world the values would be dielectric/coating/etc dependent but relative values would already be very helpfull.
Does such a tool exist? I've searched a lot looking for it but can't find anything.
Best regards!
Edson Brusque
    0 e14 Contributor over 13 years ago in reply to edsonbrusque
    Edson Brusque wrote:
    >I know how to calculate it. Put it's impracticall to calculate the
    >capacitance between each pair of tracks by hand.
    >Even two tracks would already give a lot of work if they have ood
    >shapes, angles or curves.
    >That's why I'm looking for a software that could make these
    >calculations from the actual board design. It doesn't even need to
    >work with Eagle. It could use the generated Gerber files.
    have a look at 'traceres.ulp' from
    http://www.cadsoft.de/downloads/ulps.
    I don't know if it does what you need, but it mentions track
    capacitance in the description.
    on the other hand, if you know how to do the calculations and know a
    little bit about programming, you could write your own ULP.
    Lorenz
  • edsonbrusque
    0 edsonbrusque over 13 years ago in reply to andrewk182
    Hello Andrew!
    I know how to calculate it. Put it's impracticall to calculate the capacitance between each pair of tracks by hand.
    Even two tracks would already give a lot of work if they have ood shapes, angles or curves.
    That's why I'm looking for a software that could make these calculations from the actual board design. It doesn't even need to work with Eagle. It could use the generated Gerber files.
    Best regards!
    Edson Brusque
  • andrewk182
    0 andrewk182 over 13 years ago
    here's some link's that may help you
    http://www.technick.net/public/code/cp_dpage.php?aiocp_dp=util_pcb_imp_calculator
    http://www.google.com/#hl=en&sugexp=les%3Bcpsugrpq1high&gs_rn=2&gs_ri=hp&gs_mss=trace%20capacitance%20calculator%20&qe=dHJhY2UgY2FwYWNpdGFuY2UgY2FsY3VsYXRvciB0b29s&qesig=-maq81tLQEwI-2qZtZn5Dg&pkc=AFgZ2tkojuddbXiDds-9fHqKNFP9n0opA7J5x7jEGckBZneaqpEIOYcuOcdOAQALrMzxqTDrUvrzx5A369SSg4TTrI8ekKZ3Cg&cp=33&gs_id=2o&xhr=t&q=trace+capacitance+calculator+tool&es_nrs=true&pf=p&tbo=d&sclient=psy-ab&oq=trace+capacitance+calculator+tool&gs_l=&pbx=1&bav=on.2,or.r_gc.r_pw.r_cp.r_qf.&bvm=bv.42080656,d.dmg&fp=3bb3f127af0989fe&biw=1135&bih=890
