EAGLE User Chat (English) Why does Eagle not install itself in a common Folder
  • Views 509 views
Hi
I am curious, everytime you install Eagle it creates a new  Folder for that version.
Like most programs do, they un-install the previous version or delete all files and copy everything in the
same folder, otherwise you have to go and un-install the previous version at every update.
I can understand if it was a Major Revision with file structure changes or a Beta version where you would copy them
in their own Directories but I don't understand this reason for this design?.
Peter
    Joern
    After reading your comment I did another test installing Eagle, I took notice of the path/folder name and found you can change it
    which I never took notice before, maily because during the install I just click next, next....
    The fact the folder name is always the Eagle version made me think it was done on purpose
    and you had to follow the same name.
    Am 06.03.2013 12:36, schrieb pmaroudas:
    Hi
    Peter
    http://www.element14.com/community/message/71355#71355/l/why-does-eagle-not-install-itself-in-a-common-folder
    I don't know what you are talking about. I can install eagle where I
    want it. It's up to you if you want to install it into a new folder or
    into the previous one. No problem at all image
    Joern Paschedag
