EAGLE User Chat (English) Import a component from a library to another. Importer un composant d'une librairie à une autre.
  • Views 1081 views
Hi
How to import a component from a library  "A" to a library "B" without using separated copy / paste for device, package and symbol? (i.e. import a complete component in one operation)
Bonjour.
Comment faire pour importer un composant à partir d'une bibliothèque «A» vers une bibliothèque "B" sans utiliser les copier/coller séparés des Device, Package et Symbol ? (c'est à dire importer un composant complet en une seule opération)
    0 e14 Contributor over 13 years ago in reply to autodeskguest
    Thanx :-)
    0 autodeskguest over 13 years ago in reply to e14 Contributor
    Oops - omitted the 1st step - "Open Library"
    Works like a charm.
    http://www.element14.com/community/message/73311#73311
    Hi
    Thanks for asking this question.  I've used the procedure described above to get access to a package
    Is there another more elegant way to get access to packages?
    Please advice,
    Pieter
    Jean-Pierre GELINEAU wrote:
    Hi
    Open destination library.
    Back in Control Panel locate the device of interest.
    Right click the device and select "Copy to library"
    Warren
    news.cadsoft.de
