EAGLE User Chat (English) Is a 2-layer board layout possible?
  • Replies 9 replies
  • Views 1695 views
  • board
  • layout
  • smd
  • pcb
Schematic: https://dl.dropbox.com/s/y8nm9584hz4x33h/Schematic.sch?token_hash=AAFU_Rq0QFE4vWGsSKgAa5PnrlJ3iauYhSaMfxp1HpdA-A&dl=1
I've tried several board layouts, but unfortunately the autorouter has only reached 67%. I'd love it if someone could come up with a successful layout, but either way I am in need of tips on how to arrange a board that the autorouter can handle.
    For something this small, I personally wouldn't use the autorouter at all image
    As a general rule, route as much as you can on one layer, and only when you can't route anymore go to the second layer. Also, avoid 90˚ bends, 45˚ just looks better!
    Just for reference, here's a board I routed almost completely by hand - once you get the hang of it, it's actually fun!
    0 autodeskguest over 13 years ago in reply to e14 Contributor
    There is are several ULPs (just wrote a new one) to generate the DSN
    input file for Freerouter. After routing in generates a script to update
    the BRD file. Look in the Freerouting forum on its website.
    Autorouting smartness / capabilities is very impressive.
    http://www.freerouting.net/index.php?page=description
    Robert
    On 05/04/2013 18:57, Daniel Dobrosky wrote:
    Apologies, I sneakily updated the .sch a little while after I posted the
    image files. How did you get freerouter to work with eagle?
    http://www.element14.com/community/message/73390#73390
    aaaaaand, https://www.dropbox.com/s/nm2zpfq66rnis9c/FINAL.png
    IT PASSED. Thanks all for the help.
    https://www.dropbox.com/s/ri00610jbq5q9j0/BoardFINAL.png
    Here it is, though the DRC failed merely due to the pin spacing on the LPC2138FBD64/01,15LPC2138FBD64/01,15. Maybe it will pass the BatchPCB DRC...
    Hand-routed, by the way (as if you couldn't tell).
    0 e14 Contributor over 13 years ago in reply to autodeskguest
    Apologies, I sneakily updated the .sch a little while after I posted the image files. How did you get freerouter to work with eagle?
    On 05/04/2013 16:12, Daniel Dobrosky wrote:
    Image of schematic:
    https://www.dropbox.com/s/o6p5b2vr4zk7hd9/SchematicImage.png
    Image of preliminary board layout:
    https://www.dropbox.com/s/h8xbk6w6xwpputr/LayoutImage.png
    You say hand-routing isn't that hard... is ther a method I can follow to
    minimize trial and error (i.e. "route power lines first" or something
    like that)?
    http://www.element14.com/community/message/73382#73382
    As example .brd file zipped, 100% routed with Freerouter, 39 via's (not
    cleaned up). But I think the schematic you put on dropbox was missing a
    connector.
    Schematic.zip
    Image of schematic: https://www.dropbox.com/s/o6p5b2vr4zk7hd9/SchematicImage.png
    Image of preliminary board layout: https://www.dropbox.com/s/h8xbk6w6xwpputr/LayoutImage.png
    You say hand-routing isn't that hard... is ther a method I can follow to minimize trial and error (i.e. "route power lines first" or something like that)?
    Daniel Dobrosky <noreply-178531@element14.com> wrote:
    Schematic:
    Route by hand. It's not taht hard .
    Uwe Bonnes                bon@elektron.ikp.physik.tu-darmstadt.de
    Institut fuer Kernphysik  Schlossgartenstrasse 9  64289 Darmstadt
    Tel. 06151 162516 -
    Fax. 06151 164321 -
    0 shabaz over 13 years ago
    You may wish to post a jpg image of it too (helps people reading this site from a mobile device, or those who are not running EAGLE on their current computer).
