EAGLE User Chat (English) Signal without component, only drill
  • Subscribers 189 subscribers
  • Views 734 views
  • pad
  • eagle
  • pcb
  • cad
Hi everybody,
My problem is no doubt a very common one, but due to my mother language (french)
i haven't been able to solve it through google. And i have to confess i succeeded 3 years ago
while i was in internship (thx to my internship supervisor).
Let me explain :
My purpose is to plug classical 3,5mm audio jacks in my board. both L,R and GND are
physically wires.
Thus i wan't to put pads/drills in my pcb and not a specific hardware component.
Am i supposed to create a custom component without a footprint ? (jacks included in my schematic)
Am i supposed to see my jacks as external signals in my schematic ?  (jacks not included in the schematic)
Please explain me the right way to see (and then solve image my situation)
Thanks very much !!
Tom
  • dukepro
    0 dukepro over 13 years ago in reply to e14 Contributor
    On 07/02/2013 10:53 PM, Tom Modeste wrote:
    In both case i'm supposed to replace my male plugs by signals am i right
    Correct.  Instead of the 3.5mm receptacle, add three separate wire pads
    to your schematic.  These can be found in wirepad.lbr that was
    distributed with Eagle.  Connect each of the symbols on the schematic to
    your L, R, and GND signals, respectively.
    When you switch over to the board layout editor, you will see the three
    wire pads that were just added.  Airwires connect the pads to their
    respective signals.  First, move each of the wire pads to appropriate
    locations on your board.  Put them in a place that is easily accessible
    since you will be soldering wires into each.  You may consider leaving a
    little extra room around each pad to help avoid solder splashes and
    shorts.  Once you have the pads placed on the board, route the signals
    to each of the pads.
    When you are done laying out the board, don't forget to do a DRC.  This
    will check for a number of errors.
    HTH,
        - Chuck
    0 e14 Contributor over 13 years ago in reply to autodeskguest
    Okay,
    Sorry i didn't answer earlier, i didn't mean to be rude, i just wasn't notified of your answers.
    I'm very grateful, both suggestions make it.
    In both case i'm supposed to replace my male plugs by signals am i right ?
    Merci encore (thanks again)!
    Tom
    0 autodeskguest over 13 years ago in reply to autodeskguest
    Richard Herman wrote on Fri, 28 June 2013 14:14
    Op Fri, 28 Jun 2013 17:30:36 +0200 schreef Tom Modeste
    <noreply-196115@element14.com>:
    hardware
    component.
    If I understand this correctly, you just can add a wirepad (from
    wirepad.lbr or make your own). They are just a single pad with a pin to
    connnect it in the schematic.
    Another solution is to use a raw via.  And then start our route at the via
    and route where you want.
    Cheers,
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    component.
    Richard
