EAGLE User Chat (English) Making pads with oval holes
  • Replies 7 replies
  • Subscribers 187 subscribers
  • Views 1324 views
thomaser
thomaser over 13 years ago
I am running Eagle 4r16 and was asked about making a pad with an oval plated through hole (mounting tab for a soldered in connector support).
Is there a way to generate this type of through hole pad in Eagle 4x. Preference would be to build it into a library geometry if possible.
    0 autodeskguest over 13 years ago in reply to autodeskguest
    On 9/11/2013 3:03 PM, James Morrison wrote:
    I think this all highlights why a better solution is required.  It's not
    that EAGLE can't make it work.  But when you do this sort of thing there
    are way too many places where EAGLE doesn't help and you can end up with a
    dead board.  And having a slot for a connector pin (think DC barrel power
    plug) is very common-almost on every board I do.  Whatever the solution it
    should be able to be specified in the library, work no matter how many
    layers there are, and be captured by the DRC when it's not done correctly.
    Cheers,
    James.
    Hi James,
    I fully agree, there needs to be a better way because currently all of
    the workarounds have pitfalls. The solution will come, I just don't know
    how soon.
    Let's see what comes out in the next release.
    Best Regards,
    Jorge Garcia
    Jorge Garcia wrote on Wed, 11 September 2013 14:22
    Cheers,
    James.
    Hi James,
    Whenever possible, I've avoided plated ovals and slots in PCBs in the past
    because they've always cost an additional arm and leg. I just use an
    appropriately sized hole for those crazy rectangular pins, and a little more
    solder. That said, I'm an engineer not a PCB designer by trade, and I
    haven't been inside a PCB fab facility in years. Are plated slots now common
    enough that there isn't much of a difference in cost anymore? I'm curious
    what the state of the art is these days. Thanks image
    Bob
    It's not that easy Jorge.  If you do that, then internal power
    planes will
    not have cutouts for the milled out area.
      As a result, your pad will be
    connected to all the internal layers when you have your board
    manufactured.
      That means all our internal layers will be shorted together too.
    EAGLE
    doesn't handle this well and we need much better way to handle
    these.
    Thanks for bringing this up I was aware of it and thought I had put
    mention of that in the procedure, I've corrected that now.
    Right now, the best workaround I have is to add the wires added on
    layer 46
    to layer 20 (dimension) as well.  The copper pouring will honour
    that and
    create openings on internal power planes.  However, this won't work
    if you
    actually do want the pad to connect to those internal pads.  So
    currently,
    there is no generic, fool-proof way to do this.
    Don't use the lines on layer 20 since as you've already mentioned it
    will mess with the connectivity. The better solution would be to use
    cutout polygons on the inner layers so the pours refrain from shorting
    to the slot but the autorouter can still reach the pad without
    incurring
    in errors.
    Please CadSoft, fix this soon.
    Hi Jorge,
    I tried the cutout polygon solution, but that isn't perfect either.  I
    would prefer to do that in the library so that I only have to do it once.
    But you'd have to put a cutout polygon on every layer.  But on some layers
    I could want connectivity so that doesn't work depending on how the device
    is connected in the schematic.  Also, I can't recall for sure, but I think
    there was a problem if I had a cutout polygon on layer 8 but my PCB didn't
    have a layer 8--I think that I got an error in that case and I couldn't add
    the device (though I could be wrong about that).
    So then you could put a cutout polygon into the PCB, but then you have to
    do that for every layer and for every pin EVERY time you insert that part
    into a design (if you forget then you'll have fused inner planes).  And if
    you have that done perfectly and then move the component you have to
    remember to move those other polygons as well--and if you forget you'll get
    fused inner layers.  And the worst part is the DRC won't complain about
    it.
    Cheers,
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    It's not that easy Jorge.  If you do that, then internal power planes will
    connected to all the internal layers when you have your board manufactured.
      That means all our internal layers will be shorted together too.  EAGLE
    doesn't handle this well and we need much better way to handle these.
    Right now, the best workaround I have is to add the wires added on layer 46
    to layer 20 (dimension) as well.  The copper pouring will honour that and
    create openings on internal power planes.  However, this won't work if you
    actually do want the pad to connect to those internal pads.  So currently,
    to the slot but the autorouter can still reach the pad without incurring
    in errors.
    Cheers,
    James.
    Jorge Garcia wrote on Tue, 10 September 2013 15:40
    On 9/5/2013 10:06 AM, Ernie Thomas wrote:
    I don't know how it got changes, but that was supposed to be Eagle
    4.16... not 6.16... I wish I had version 6 available...
    http://www.element14.com/community/message/88377#88377
    Hi Ernie,
    It is possible, I've attached a short procedure for that.
    hth,
    Jorge Garcia
    In order to make slots follow this procedure:
    1. For the moment ignore the drill hole worry only about getting the
    overall pad shape close to the size you need.
    2. Once the pad is approximately the correct size you can draw in the
    opening using the WIRE command on a non-copper layer such as milling
    Layer 46.
    3. When you go to generate the gerbers you will generate a separate
    gerber file containing only layer 46. You will tell your board house that
    the info on that gerber needs to be milled from the board. Let me know if
    there's anything else I can do for you.
    not have cutouts for the milled out area.  As a result, your pad will be
    Cheers,
    James.
    Hi Ernie,
    hth,
    Jorge Garcia
    Make_slot_drills.txt.zip
