EAGLE User Chat (English) Customized gerber output
  • Subscribers 187 subscribers
  • Views 369 views
  • customizing
  • eagle
  • Processor
  • cam
Rogerrose
Rogerrose over 12 years ago
Would like to customize the gerber output of the cam processor.
The gerber outputs the coordinates in mils(1/1000th of inch) and would like the output in inches.
For example the output is 1000 rather than 1.000
I tried changing the %d parameter and others in the Device Driver Definition in eagle.def with no success.
The number of leading zero and trailing zeros will change and I was able to remove some of the extra characters.
    0 autodeskguest over 12 years ago
    Are you sure you understand how it should look?
    Out of the box, Eagle does its Gerber in inch.
    There is no decimal point in the coordinate number. The format is
    specified in the first few lines of the file, normally 2.5 or 2.4
    Spot the lines in the devices that contain , say, X24Y24.
    In the gerber output file you see the same string telling the gerber
    plotter what the format of the coordinate system is.
    That specifies the first 2 numbers are the inches and the following 4 or
    5 numbers are the decimals of an inch
    HTH
    Warren
