EAGLE User Chat (English) Silly newbie question: Switch between schematic and library editors from keyboard
  • Views 502 views
  • shortcuts
  • library
  • schematic
I'm a relative newbie to Eagle, using it on the Mac.  Hence, the standard Windows OS keyboard shortcuts do not work.
Now, in my workflow I regularly need to switch between the schematic editor and the library editor.  Even with googling, I haven't found any keyboard shortcut for that.  I didn't find any command either, so that I could define a keyboard shortcut myself.  I even tried "edit .lbr", but it simply closed the schematics window and created a new schematic ".lbr.sch".
So, is there a command for switching between the schematic editor and library editor?
I'm using Eagle 6.5.0 (and 6.5.2 beta).
--Pekka Nikander
    Never mind.  I found the answer.  Trick is to use Mac OS X "Spaces", placing the editor windows on different spaces.  Then I can use CTRL+arrows to switch between the editor windows.
    --Pekka
