EAGLE User Chat (English) Linux Installation Pain
  • Replies 11 replies
  • Subscribers 190 subscribers
  • Views 1651 views
  • linux
There might be a good argument for me not understanding quite how to install Eagle on Linux, but I have however not been able to instal the demo as specified in the simple instruction given on the Eagle www HERE
I have allowed the file to be executable and tried opening it as sudo and directly and the terminal window opens and then exits about 5 seconds later with no indication of what happened.
Linux Mint Cinnamon not sure of the Kernel, but latest version with updates as of 12/3/2014
Baring in mind this program costs a packet... what am I to do to get the executable running for the demo version?
    0 autodeskguest over 11 years ago in reply to backwoodsjack
    Fantastic, good find. I've been using XFCE for so long I didn't even think about other window managers.
    Have fun,
    Eric
  • backwoodsjack
    0 backwoodsjack over 11 years ago in reply to autodeskguest
    i found something that i could make work--on ubuntuforums
    http://ubuntuforums.org/showthread.php?t=441069
    so i made a eagle.sh and with what u provided me earlier and this command ,
    i am happily working on my first project while on my ubuntu laptop--
    thankyou sir..
    On Tue, Nov 25, 2014 at 11:31 AM, cadsoftnntp <messages@element14.com>
    https://community.element14.com/cfs-file/__key/communityserver-discussions-components-files/309/eagle.sh
  • backwoodsjack
    i dont see a windows manager or a settings manager.. i have the classic
    gnome shell..got system settings>>appearance and displays..but nothing
    there about windows manager..
    i have dconf also.. looked there..dont see what u say to go tweak..
    0 autodeskguest over 11 years ago in reply to autodeskguest
    I'm all thumbs today. That should be 'Compositing' in the Window Manager Tweaks of Settings Manager.
    Eric
    Turn off composting in Window Manager Tweaks.
    Eric
  • backwoodsjack
    thankyou very much.. that worked great..i can now get to the
    license/freeware screen..
    i noticed that it has some transparency issue..its there but kinda funny..i
    can see eagle if its over a dark background (like terminal)..i tried to
    write a xorg.conf with the 'fix' i found at cadsoft and just about lost
    everything..blank screen..reboot in recovery and just barely was able to
    rename xorg.conf to something else..wow..nerves bad now..i will take a
    break..
    thanks again..
    jack in arkansas
    I tried installing and running Eagle 4.09r2 on 14.04 and received the same response when trying to run it. The following package contains libstdc++-libc6.2-2.so.3 and should work after installing it.
    wget http://archive.debian.org/debian/pool/main/g/gcc-2.95/libstdc++2.10-glibc2.2_2.95.4-27_i386.deb
    sudo dpkg -i libstdc++2.10-glibc2.2_2.95.4-27_i386.deb
    Eric
  • backwoodsjack
    0 backwoodsjack over 11 years ago in reply to AnalogNotes
    thanks for that STRACE command..it helped me with my eagle----ubuntu install problem..but still wont run..I am trying to install my eagle-4.09r2 on ubuntu 14.04...it throws error when i try to launch eagle.. shared file not found..libstdc++-lib6.1-1.so.2  i have located those old files on the web and have installed them where STRACE shows it was looking..still doesnt see the file..?? i'm lost..
  • AnalogNotes
    0 AnalogNotes over 12 years ago in reply to e14 Contributor
    Ooops, I obviously misunderstood...  image
    How comfortable are you with files and the shell under Linux?  That run file is basically just a compressed tar file embedded in a shell script.  I think the first thing to try is to specify an install directory on the command line.  Something like:
    ./eagle-lin-6.5.0.run eagle-6.5
    Which should create a subdirectory called "eagle-6.5" in the current directory.  If that doesn't work, you can try using an editor to remove everything before and including the "__DATA__" line in the file and then use the tar command to extract the contents.  Recent systems should understand how to deal with the bzip2 compression already, so you can just use "tar xf" on the data part.  For example, if you're familiar with vi (might be installed as "vim"):
    CommandExplanation
    vi eagle-lin-6.5.0.runuse vi to edit the file
    /^__DATA__search for the line that starts with "__DATA__"
    :1,.ddelete everything from the beginning of the file
    :w eagle.tar.bz2write the data to a different file name
    :qquit
    tar xf eagle.tar.bz2extract the contents of that file
    (Sorry about the table, I couldn't figure out a better way to format that.  This site sucks for inserting formatted text.)
    Then you can cd into the eagle directory and down into the bin directory to see if the EAGLE program will run...
    0 e14 Contributor over 12 years ago in reply to AnalogNotes
    Hi there Doug,
    I dont think the package has even unpacked from the file download (eagle-lin-6.5.0.run). When allowing it to be executable and running it in shell and directly it just exits and no extraction script seems to have run. There are no files created, or no dialogue for the script as expected.
    Best
    J
