EAGLE User Chat (English) Can I force Eagle to do single-sided PCB
  • Answers 3 answers
  • Subscribers 189 subscribers
  • Views 2886 views
faceter
faceter over 12 years ago
I'm new to Eagle (Freeware Licence) and am doing the exercises to gain some competence with it.  Slow going thouh, finding parts is a nightmare for me.
Suppliers don't use siilar numbers et.
Anyway, that is not my question.
Most of my exercises result in 2 layer PCB.   Can I forc a single ;ayer PCB.   I want to make my own PCBs
    when you click on autorouter option the menu pops up just change top to na and voila you will have single sided routes
    0 autodeskguest over 12 years ago in reply to faceter
    On 18/03/14 19:43, Arthur Rodman wrote:
    Hi, and thanks for the response.  Reading what you've written it seems
    that I can't do a single sided board really,
    Yes, you can. I have done, often, and we use Eagle to design the
    single-sided boards for young people to etch on an SU holiday I help on.
    If I use the top copper layer to represent the link wires then it's
    double layer after all.
    No, because you don't need to etch the top layer. What I'm suggesting is
    that, as you lay out your circuit, you will undoubtedly hit a point
    where you just can't route a signal and you need to put in a link wire.
    Since that link wire exists only for routing purposes and is not part of
    the circuit, you don't really want the hassle of adding a
    pseudo-component. Instead, what you do is "route it on the top", making
    sure you avoid components and use a straight track if possible. Then
    when you come to etching, you ignore the top layer entirely and just
    etch the bottom. When you have drilled the board and are ready to
    populate, show the top layer again as your "wire links population guide".
    I do wish to etch my own etching (nothing grand I hasten to say) and was
    thinking of using the toner transfer approach
    I've not tried toner transfer. If home-etching I use a transparency and
    UV exposure box. However, the design approach is the same.
    Either way, thanks a lot for your input.
    You're welcome.
  • faceter
    0 faceter over 12 years ago in reply to autodeskguest
    Hi, and thanks for the response.  Reading what you've written it seems that I can't do a single sided board really,
    If I use the top copper layer to represent the link wires then it's double layer after all.
    I do wish to etch my own etching (nothing grand I hasten to say) and was thinking of using the toner transfer approach
    hence single-sided.   If I have to utilise both sides of the board then I'm not so sure about toner transfer.
    The best way to design a single-sided PCB is not using the autorouter.
    There is a tutorial (and example in the base install) for how to
    "encourage" the autorouter to avoid the top layer, but you'll find it
    struggles. Better to route it yourself and just not use the top.
    Of course, if you're doing your own etching, you can always use the top
    copper layer to represent the half-dozen link wires you just can't avoid
    with a single-sided board image
