EAGLE User Chat (English) Where can I find a library of relays automotive flat pin with pin 6mm x 1mm?
  • Views 2019 views
  • relè
    0 dougw over 12 years ago in reply to e14 Contributor
    VCF4-1000 - TE CONNECTIVITY VCF4-1000 - RELAY SOCKET | Newark element14 Canada
    0 e14 Contributor over 12 years ago in reply to dougw
    Dear Douglas,
    You've been very helpful. This socket would help me a lot, but you could not find it in Brazil. Let me know a place to buy it online?
    Thank you.
    Rodrigo Carpe
    Normally you would use a socket with a relay like this allowing round through holes in the PCB.
    Here is a VCF4-1000 socket:
    Altenatively:
    You can draw composite pads with slots in Eagle, but may end up with DRC overlap errors that need to be waived.
    Here is what the manual suggests:
    8.13 Components with Oblong Holes
    If the board manufacturer has to mill oblong holes, you have to draw the milling contour of oblong holes in a separate layer. Usually this is layer 46, Milling.
    The milling contour for components that need oblong holes can be drawn with WIRE (and possibly ARC) with a very fine wire width near or even 0 in the Package Editor. Take a pad that has a drill diameter which lies inside the milling contour, or SMDs, for example in Top and Bottom layer, as basis for the oblong hole.
    In case of a multilayer board you should draw a WIRE in the used inner layers at the position of the oblong holes so that it covers the milling contour and leaves a kind of rest ring around the opening.
    Please inform your board manufacturer that they have to take care on the milling data drawn in this layer. Also tell them whether they should be plated through or not.
    Any other cutouts in the board are drawn in the same way:
    Use a separate layer, typically layer 46, Milling, and draw the milling  contours. Tell your board manufacturer that they have to take care with  this information and make special note.
    Hi Douglas!
    But I need a library for that relay. I found the model on the manufacturer's site you indicated, but they do not offer the Eagle files.
    I tried creating my own library for this component, but the Eagle has the option of flat pin, round pin only.
    Look up
    Power Relay B from TE Connectivity / Potter & Brumfield
    Sometimes called plug-in relays
