EAGLE User Chat (English) Need some Eagle Netlist format explanation
  • Views 1554 views
  • netlist
  • schematic
Hi -
I use to use Eagle back during Rev 4.x.  Now I have a need to write a ULP that will customize the NetList output for a unique application.
Would someone explain the following Netlist output:
Exported from EagleTest2.sch at 9/5/2014 8:46:11 AM
EAGLE Version 7.0.0 Copyright (c) 1988-2014 CadSoft
Net      Part     Pad      Pin        Sheet
N$1      J1       1        S          1
            J1        2        S          1
            W1       1        1          1
N$2      J1        5        S          1
            W2       1        1          1
N$3      J1        3        S          1
             J1       4        S          1
            W3       1        1          1
N$4      P1       1        S          1
             P1       2        S          1
            W1       2        2          1
N$5      P2       2        S          1
N$6      P1       3        S          1
            W3       2        2          1
This simple test netlist is simply some net connections from one connector to another connector.  The Wx components are components that I created.  All of the connectors were prebuilt libraries.
Please explain why the connectors show the pin as 'S' in the pin column?  I'm sure this is something simple but I cannot seem to understand why.
Inspecting the part library does not reference 'S'.  Your help would be appreciated.
Jim Flanagan
Largo, Florida
    0 autodeskguest over 12 years ago in reply to e14 Contributor
    On 6/09/2014 9:42 a.m., Jim Flanagan wrote:
    Thanks Warren -
    I will find a copy of Ver 6 and try exporting the net list.
    http://www.element14.com/community/message/125791
    ftp://ftp.cadsoft.de/eagle/program/
    0 e14 Contributor over 12 years ago in reply to autodeskguest
    Thanks Warren -
    On 6/09/2014 5:22 a.m., Jim Flanagan wrote:
    Hi -
    N$1      J1       1        S          1
                 J1        2        S          1
                 W1       1        1          1
    N$2      J1        5        S          1
                 W2       1        1          1
    N$3      J1        3        S          1
                  J1       4        S          1
                 W3       1        1          1
    N$4      P1       1        S          1
                  P1       2        S          1
                 W1       2        2          1
    N$5      P2       2        S          1
    N$6      P1       3        S          1
                 W3       2        2          1
    understand why.
    appreciated.
    Jim Flanagan
    Largo, Florida
    Hi Jim
    I feel that doesn't look right at all. You may have revealed an issue
    with Version 7.
    I suggest you practice with an export of the net list of the example
    singlesided.sch that comes with eagle. Heres the first few lines of that
    (using v6.6)
    You can see the pin names of the symbol and the pad they are associated
    with (connected) in the library.
    Exported from singlesided.sch at 6/09/2014 7:21:49 a.m.
    EAGLE Version 6.6.0 Copyright (c) 1988-2014 CadSoft
    +12V     C1       +        +          1
              C3       2        2          1
              J1       2        2          1
              U1       3        VI         1
    A0       IC1      17       RA0        1
              J1       4        4          1
    A1       IC1      18       RA1        1
              J1       5        5          1
    HTH
    Warren
