EAGLE User Chat (English) Polygon pour hatch eagle with 45º of angle
  • Views 912 views
  • eagle
rekeijao
rekeijao over 12 years ago
Hi ,
I need to create a polygon pour hatch eagle at 45 º angle for shielding of capacitive proximity sensor ,can me help me?
Thank you
  • jameslittlefield
    0 jameslittlefield over 12 years ago
    Warren is right!    You can't generate polygon hatch fill at 45 deg ..... but you can rotate the entire board 45 deg.  then do a ratsnest, then run the cam processor to generate the gerbers!     Then either you or your board house can rotate the generated gerbers -45 deg and you'll have 45 deg cross hatch!
    Cheers,
    Jim
    0 autodeskguest over 12 years ago
    Hi
    Eagle cannot do 45 degree hatching.
    HTH
    Warren
