EAGLE User Chat (English) how do i find IC in eagle
  • Subscribers 190 subscribers
  • Views 3157 views
how do i find IC LM317 in eagle library?
    0 autodeskguest over 10 years ago in reply to omega-5
    Am 22.09.2016 um 11:17 schrieb Friedrich Bleikamp:
    Am 21.09.2016 um 14:37 schrieb Joop:
    zulqarnain bokhari wrote on Thu, 02 October 2014 00:54
    So far, this works best and fastest for me:
    Open a console and enter:
    cd eagledir/lbr
    grep -i lm317 *.lbr
    on Windows I use "Total Commander"
    Commands --> Search --> Find text
    Kind regards
    Friedrich
    ... use NNTP://news.cadsoft.de and a
    functional news reader like Thunderbird!
    After 2 Years it should have been  found image
    Joern Paschedag
  • omega-5
    0 omega-5 over 10 years ago in reply to Joop14
    cd eagledir/lbr
    grep -i lm317 *.lbr
    Kind regards
    Friedrich
  • Joop14
    0 Joop14 over 10 years ago
    cd eagledir/lbr
    grep -i lm317 *.lbr
  • jwhitten
    0 jwhitten over 10 years ago in reply to autodeskguest
    In Eagle 7.6.0 it seems to be under the "View" menu, "Search in Tree" (CTRL-F) that opens the Search bar at the bottom of the control panel.
    0 autodeskguest over 12 years ago
    Am 02.10.2014 um 00:54 schrieb zulqarnain bokhari:
    http://www.element14.com/community/message/127589
    In the ADD dialog is a search line at the very  bottom...
    The asterix (*) means all.
    Different manufacturer have different identification characters for
    their products, like LM or µA etc.
    So use the asterix for your search and search "un-sharp" just for the
    number like lm317*.
      317 would mean, any characters before and behind 317.
    Try that and see what comes out image
    Joern Paschedag
    In the Control panel
    Right click on Libraries
    A search bar will open at the bottom
    Enter LM317*
    Click Next Next Next... until you spot what you are after.
    Some of the results have multiple packages so make sure you check then out
    Searching is explained in the manual which you will find in the doc folder
    of your installation
    HTH
    Warren
