EAGLE User Chat (English) Library part changes when imported into PCB
  • Views 655 views
Hi
I'm a new user of Eagle (V6.6.0 - have not dared upgrade part way through a project).
I have made a library part which is a PCB coil terminated in vias.
The vias and their drills are very small (less than the standard vias in the PCB editor) and the size is critical.
This coil is used multiple times on two related PCBs (which is why I wanted it as a library part).
When I import the part into the PCB, the coil bit is fine, but the via pads come out larger than they should be (but the drill holes are the correct size).
I would be ever so grateful if someone could point the way top getting the part to import as drawn.
    correct size).
    <http://www.cadsoft.de/training/faq/#11>
    Tilmann
    0 e14 Contributor over 11 years ago in reply to autodeskguest
    Werner
    Thank you so much!
    I had set up in the "Sizes" tab, but not in "Restring".
    Problem solved.
    Thanks again
    Mike
    Am 03.11.2014 um 15:13 schrieb Mike Hunter:
    Hi
    through a project).
    correct size).
    Hello Mike,
    have a look to the DRC in the restring tab.
    and in the help-> restring. Maybe there are the values to
    great.
    (sorry for bad english -> german speaking person image
    HTH
    Werner
