EAGLE User Chat (English) Micro Via Setup/Limitations
  • Subscribers 186 subscribers
  • Views 722 views
  • eagle
  • blind
  • pcb
  • micro
  • cad
  • vias
  • via
I'm trying to create a PCB with a BGA component and I'm struggling with getting micro vias to work. Currently my setup is [2:(1*(2*(3*14)*15)*16):15] but I can only get a micro via to go down one layer whereas I need it to get down to the third layer. What is the proper setup for micro vias in eagle and are there limitations in how deep a micro via can go?
Best Regards
    0 autodeskguest over 12 years ago
    "Osi Van Dessel"  skrev i nyhetsmeldingen:
    384052329.461415728160817.JavaMail.jive@flmspu-csapp-02.premierfarnell.com
    [2:(1(2(314)15)*16):15] but I can only get a micro via to go down
    This is a limitation of the manufacturer only. If you really want to do this
    and are aware of the high costs, I suggest you google for standard HDI
    types.
    As an extract, you have the choise of different microvias in the "HDI type
    2" standard:
    - stacking mirovias on top of each other
    - use staggered type (microvia between layer 2-3 slightly offset from 1-2)
    - stepped microvia (1-2 slightly larger diameter than 2-3).
    - skipped microvia (direct from 1-3 with no connect to 2). (I dont think
    Eagle can DRC this)
    Make sure you agree what the manufacturer can do, and the cost is within
    your reach before you start designing.
    Maybe this is the stackup you look for:
