EAGLE User Chat (English) Why does eagle play an error sound every time I lay a signal manually on the PCB?
  • Views 2024 views
Im brand new to eagle.  It's getting annoying to hear the "bump" error sound when I lay a signal.  I'm connecting parts that are supposed to be connected, is this supposed to make noise? can I turn it off somehow?
    0 autodeskguest over 11 years ago in reply to autodeskguest
    ...and in the options you can turn off this "error" image
    in the command line type
    SET BEEP OFF
    See HELP "SET" Beep On/off
    HTH
    Warren
    0 autodeskguest over 11 years ago in reply to kikoun
    Am 02.03.2015 um 12:53 schrieb Guillaume barrey:
    This is not an error, it just means that your route reached the final
    destination of you air-wire... That is useful because sometime you may
    end-up your wire near the pad, but not exactly at the center of the
    pad... if you heard the sound, you are sure the you reach the center (no
    need to zoom in to check).
    I work on windows and on Linux platform, and on linux (KDE) this feature
    doesn't work (maybe it's a trouble with my computer) and I miss this
    when I work on linux...
    Guilluame
    http://www.element14.com/community/message/142175
    Joern Paschedag
  • kikoun
    0 kikoun over 11 years ago
    This is not an error, it just means that your route reached the final destination of you air-wire... That is useful because sometime you may end-up your wire near the pad, but not exactly at the center of the pad... if you heard the sound, you are sure the you reach the center (no need to zoom in to check).
    I work on windows and on Linux platform, and on linux (KDE) this feature doesn't work (maybe it's a trouble with my computer) and I miss this when I work on linux...
    Guilluame
