EAGLE User Chat (English) making componet location file.
  • Replies 7 replies
  • Subscribers 191 subscribers
  • Views 925 views
ulao
ulao over 11 years ago
I need to make a coordinate file for my factory and they want it in a specific format, example below.
header
### Module positions - created on Tue Mar 22 17:58:38 2011 ### ### Printed by PcbNew version pcbnew (2010-12-28 BZR 2695)-testing ## Unit = inches, Angle = deg. ## Side : Front
each item like so
C1  2p2             2.02001.7800270.0Front
C2  1nF             2.19001.7150  0.0Front
C3  1pF             2.13321.8200 90.0Front
C4  18pF            2.19001.7450  0.0Front
how can I generate this?
  • ulao
    0 ulao over 11 years ago in reply to Joop14
    EXPORT PARTLIST did what they asked for.
  • Joop14
    0 Joop14 over 11 years ago
    Copy and paste the following code into a new file and name it "exp-coordinates.ulp".
    Put this file in the ulp directory of Eagle.
    Open your board and run this ulp.
    <<<<<<<<<<<<< the code starts after this line >>>>>>>>>>>>>>>
    #usage "<b>Export coordinates</b>\n"
           "<p>"
           "Generates a file that can be used with pick-and-place machines. "
           "The x- and y- coordinates (units: milli-meters) are taken from "
           "the origin point of the part in the layout."
           "All elements populated in currently set assembly variant are considered."
           "<p>"
           "The syntax of the output data looks like this:"
           "<p>"
           "<tt>Reference;Value;X-Pos;Y-Pos;Orientation;Side</tt>"
           "<p>"
           "<author>Author: Teunis van Beelen teuniz@gmail.com</author>"
    if(board) board(B) {
      // Get filename
      string fileName = dlgFileSave("Save File", filesetext(B.name, ".csv"), "*.csv");
      if (fileName == "") exit(0);
      output(fileName)
        printf("Reference;Value;X-Pos;Y-Pos;Orientation;Side;\n");
        B.elements(E) if (E.populate)
          printf("%s;%s;%f;%f;%f;",
                E.name, E.value, u2mm(E.x), u2mm(E.y), E.angle);
          if (E.mirror)
            printf("Bottom;\n");
          else
            printf("Top;\n");
    else
      dlgMessageBox("\n    Start this ULP in a board    \n");
      exit (0);
  • jameslittlefield
    0 jameslittlefield over 11 years ago in reply to clem57
    There are some existing ULPs to generate x,y,rot coordinates for smd parts on an eagle brd.    I think they are called "mountsmd.ulp"  or maybe just "mount.ulp".   One of these ULPs would be a good (at least) starting point.    If the OP could identify a particular machine format there might already be a ulp written.....
    Jim
  • clem57
    0 clem57 over 11 years ago in reply to autodeskguest
    I did not suggest ULP because of the coding efforts. Most are not able to tackle without many questions.
  • clem57
    I believe an excel could import and move the columns around and export again.
    0 autodeskguest over 11 years ago in reply to clem57
    On 26/04/15 02:44, Clem Martins wrote:
    Use the editor command EXPORT PARTLIST filename
    Clem
    Some post-processing may be required to achieve a specific format, if
    the board house really require that, using your text processing language
    of choice. Alternatively, a ULP could be written to generate the correct
    format directly.
  • clem57
    Clem
