EAGLE User Chat (English) Ground plane settings for RF?
  • Subscribers 189 subscribers
  • Views 795 views
  • eagle
  • plane
  • ground
  • rf
Hi guys, I'm trying to desing PCB for RF applications and I'm getting confused about ground plane....
My track is 0,75mm width and I need 0,15mm space from surrounding ground plane (to achieve specific track impedence).
I design ground plane but even setting Isolate to 0 value I still have more than 0,15mm spacing from ground; so I need to set Clearance value to 0,15mm into design rules, but in this way all tracks of board get spaced of 0,15mm.
How can I set specific spacing ONLY for specifico polygon?
Thanks.
  • dukepro
    0 dukepro over 11 years ago
    Can you add a second ground polygon immediately surrounding the 0.75mm
    track?  This would allow you to set the spacing for the portion of the
    ground plane surrounding the track different than that of the overall
    ground plane.  The DRC settings would have to be the lesser of the two,
    of course.
    spaced of 0,15mm.
    Thanks.
    http://www.element14.com/community/message/152867
    0 autodeskguest over 11 years ago in reply to e14 Contributor
    On 06/17/2015 01:42 PM, Michele Bertoni wrote:
    Thanks, but I've already read similar tutorials.....
    I've tryed to solve in this way:
    1) set Clearance value to 0 mil (wire field) into net Design rules
    2) set Isolate to 0.15mm into first ground plane (antenna ground plane)
    2) set a second ground plane for remaining PCB with standard Clearance
    value
    I don't know if this way is the correct one.....
    http://www.element14.com/community/message/152869
    Did you use the net class functions. I don't know where you access it in
    the newer versions.
    Paul
    0 e14 Contributor over 11 years ago in reply to clem57
    2) set a second ground plane for remaining PCB with standard Clearance value
  • clem57
    0 clem57 over 11 years ago
    HOW-TO: Polygons and ground fills for PCBs in Eagle | Dangerous Prototypes
    or https://www.sparkfun.com/tutorials/115
