EAGLE User Chat (English) Changing from 1 to 2 layers
  • Subscribers 187 subscribers
  • Views 604 views
I have some 1-sided (top - all parts are smd) layouts that I have
prototyped by hand (laser print and etch) and will now order 'proper'
2-sided pth boards.
These boards had many top-side jumper wires, so I want to re-route them
on the underside.
However, I am unable to route on the 2nd (in my case: lower) side of the
board.
Attempting to route an underside track produces "can't set via to layer
'16' at: <co-ords> when I try to end the trace.
I have loaded an appropriate DRC file with 2 sided copper defined but
Eagle still seems to think that it only has top copper.
What else must I do ?
Many thanks,
Bob
    autodeskguest over 10 years ago in reply to autodeskguest
    Am 05.08.2016 um 17:07 schrieb Robert von Knobloch:
    On 05/08/16 16:51, Joern Paschedag wrote:
    What setting do you have in DRC/layers?
    (1*16)
    Bob
    That is "normal". Check the properties of the via. It might have been
    connected to something else before.
    Can you ripup the top jumper including the vias and then route manual,
    change layer, route bottom,  change layer to top again and finish the
    connection .
    If nothing works you can send the board to me and I take a look if you like.
    Joern Paschedag
    (1*16)
    Bob
    Am 05.08.2016 um 16:11 schrieb Robert von Knobloch:
    2-sided pth boards.
    on the underside.
    board.
    Many thanks,
    Bob
    Joern Paschedag
