EAGLE User Chat (English) Pad size
  • Replies 12 replies
  • Subscribers 189 subscribers
  • Views 1950 views
Pad size
New to eagle, I succeed to make a schematic and a board, my own library.
While trying to custom my packages pins I am getting square, round, long
options
My problem is I don't understand how to get the long pad shorter than
round*2
For example I want to make a pad of 7056 mill but I am getting 11256.
Any advice will be appreciated
Best wishes
Joe
    e14 Contributor over 10 years ago in reply to rachaelp
    Thank you for the post Rachael
    I copy your post to my computer and will do as you advised
    In any case, The pic16f1847 is un my new 1LME.lib and the package is in my new 1LME library under the Packages
    Best wishes
    Joe
  • rachaelp
    rachaelp over 10 years ago in reply to e14 Contributor
    IOSIF GROSS wrote:
    1. I didn't succeed to copy the pad, top, bottom, top solder mask, bottom
    solder mask polygons all together so I done it one by one
    You need to group them with the group tool first, then go into copy mode, right click on one of the items in the group and select 'copy group' from the menu.
    IOSIF GROSS wrote:
    2. In the saved package, is still see the polygons and the pad and not a
    pad of 70/56 mill
    When you say in the saved package, where are you viewing this? If you've just created this package in the library you should see it in the library browser but you need to do a few more things to get it associated with the actual component.
    IOSIF GROSS wrote:
    3. Tried to replace the package of the PIC18F1847-I/P in my drawing with my
    new package, followed the manual step by step with no success.
    4. Tried to add the package to the PIC18F1847F-I/P without success.
    In general, the manual assumes that you know a lot of things already, don't
    have step by step procedures.
    Have you created the new package in the same library as your PIC part that you are using? Have you added that package as a variant to the part itself so it's available for selection? If you haven't then this is your problem. The procedure to do this is as follows:
    1. Open up your library containing the PIC and your new package (they must be in the same .lbr file)
    2. Open the PIC device to view its symbol and packages
    3. Click on the 'New' button in the bottom right.
    4. Single click on the new package you have created from the list.
    5. Give this new package a variant name.
    6. Click on 'OK'. Your new variant will appear in the list on the right hand side but it won't have a green tick against it.
    7. Double click on your variant in the list.
    8. Assign the pins in the resulting dialog by using the 'copy from' drop down to select the mapping from the existing part or manually mapping them yourself if your pin numbering doesn't quite match the original.
    IOSIF GROSS wrote:
    I am using WinQcad for many years, was/I am very happy with the software
    but I suppose you know they existence ended a few years ago and I found
    Eagle to be the most affordable and serious medium level SCH/PCB software,
    also used by Elelent14 and SpakFun.
    I have a total of some 50 Packs I am using and would like to have them in
    Eagle, most pads are 70/56 mill and round 56 mill (given by Eagle)
    EAGLE has it's usability quirks and when you are very familiar with another tool and know you can do something quickly in that tool then it can be frustrating. It does get easier and once you get used to the methodology used by EAGLE it does actually become relatively quick for a lot of things. But there is a learning curve and it take patience and practice. Keep at it and you'll get there, and if you have any more questions just ask :-)
    Best Regards,
    Rachael
    Thank you for the replay Rachaelp
    I have done what you are proposing and made an 18 pin package with pads of
    70/56 mill
    pad of 70/56 mill
    Best wishes
    Joe
  • rachaelp
    Hi Joseph,
    I agree there could definitely be improvements made here. It does get quicker with practice and as you learn little techniques for doing this.
    When you say the polygon approach was time consuming, what was your process? It'll be slower for the initial pad within the package but once you have done one pad its just a matter of setting the grid to the pin pitch and then doing a group copy of all the parts of the custom pad and pasting it for each of the pins on the first side, then setting the grid to the pitch between the two rows of pins and doing a group copy and paste of the whole first row to create the remaining pins. Then type NAME and press return and go round clicking each pin and naming it correctly to ensure all the pins are in the correct order.
    Best Regards,
    Rachael
    e14 Contributor over 10 years ago in reply to autodeskguest
    Thank you for posting CadSoft Guest.
    I am not talking about individual pads
    I am talking about all the pads the same in a component:
    Like let say 18 Pin DIP, all pads 56/70 mill
    Designing a board with long pads of 56/112 mill makes a lot of limitations to the board.
    I tried the polygon, is a very time consuming approach
    Best wishes
    Joseph
    autodeskguest over 10 years ago in reply to e14 Contributor
    On 13/08/16 00:55, Iosif Gross wrote:
    Very frustrated with this pad issue
    I know I am new here, cant ask a simple way to make a pad?
    Like defining length/width and hole?
    If all you want is an elongated through hole pad, the long hole pad
    works. Its limitation is that the ratio of length to width (and offset
    of the hole) are defined in the DRC rules for the board, not
    individually per pad. If all your long pads want to be the same shape,
    that will work for you.
    If you want something more detailed or more controllable, use the
    polygon method Morten recommends.
    e14 Contributor over 10 years ago in reply to e14 Contributor
    Best wishes
    Joseph
    Will continue the experiments
    Best wishes
    Joe
  • rachaelp
    Hi Joseph,
    To answer your questions in order:
    1.So long as the polygon surrounds the pad then EAGLE automatically merges these. Note you need to also put polygons on the mask layers otherwise you'll have the right shape copper but the mask will only be where the actual pad is.
    2. You can't save them as pads to use over and over. You create these custom pads as part of creating a footprint for a particular package.
    3. See 2 above. If you want to reuse custom pads from an existing package you'll need to duplicate the existing package or copy it into a new library and then edit it to your requirements for the new footprint.
    Best Regards,
    Rachael
    I succeed to draw two polygons I wanted as pads
    I would like to save them as pads and use them for some of my packages.
    Still don't understand:
    • How the polygons are merging with the pad
    • How to save them as pad
    • How to use them when designing a new package
    Will appreciate any help
    Best wishes
    Joseph
