EAGLE User Chat (English) local/user information in a ULP?
  • Views 870 views
mr.chris.styles
mr.chris.styles over 9 years ago
HI All,
I have scanned the extensive ULP documentation, i could well have missed it, but I have not been able to find any way for a ULP to access information about Eagle revision number, registered user, serial number, etc etc.
I'm doing some experiments with ULPs, never written them before, and the ability to understand who exactly is running the ULP would be pretty useful!
Any hints/tips appreciated..
Cheers,
Chris
    autodeskguest over 9 years ago in reply to mr.chris.styles
    Chris Styles wrote on Fri, 23 December 2016 08:24
    Thanks for the rapid reply!
    Too bad I can't get at the serial number, as that would uniquely
    identify the installation, while maintaining anonymity...
    Cheers,
    Chris
    https://www.element14.com/community/message/211665
    The ULP command "system()" may provide a solution for you.
    As an example, if your computer names provide anonymity you can get the
    computer name via the command "system()" command. The following ULP targets
    the computer name in a Windows system via the Windows cmd.exe
    The attached could be the basis of an #include ULP that is included with
    each of your custom ULPs.
    The idea could be extended to acquire any info you required from the OS.
    Alas there may be a speed penalty for the primary ULP being run.
    string myFile = "eagleULP_MyComputerName.txt";
    string myPath,syscmd,myPathFile,hostname;
    string line[];
    if(board)     board(B){myPath = filedir(B.name);}
    if(schematic)     schematic(S){myPath = filedir(S.name);}
    if(library)     library(L){myPath = filedir(L.name);}
    myPathFile = myPath + "/" + myFile;
    //create file that will be overwritten with each run of this ulp and
    removed when Eagle is closed
    output( myPathFile,"wtD");
    sprintf(syscmd,"cmd.exe /q/c hostname > %s",myPathFile); //prep to call
    Windows cmd.exe
    system(syscmd);  //place computer name into file
    //read computer name from file
    fileread(line,myPathFile);
    hostname = line ;
    //display computer name
    dlgMessageBox(hostname);
    exit(0);
    HTH
    Warren
    http://www.eaglecentral.ca :: The original and best browser access to CadSoft EAGLE support forums.  Supported by EAGLE licenses purchased through us :: http://www.eaglelicenses.com
    Am 22.12.2016 um 20:24 schrieb Chris Styles:
    While I am here, are there any plans to add "version" properties to sch, brd and library files? Another built in variable that can be set/seen in the UI, or munged directly in the XML if needed?
    Not for the library, but for the schematic and board you can add such
    information right now, through global ATTRIBUTEs. But keep in mind that
    global ATTRIBUTEs aren't really global - they are local to the drawing
    you're editing. An ATTRIBUTE added to the schematic is not visible in
    the board and vice versa.
    Rene
  • mr.chris.styles
    mr.chris.styles over 9 years ago in reply to autodeskguest
    Too bad I can't get at the serial number, as that would uniquely identify the installation, while maintaining anonymity...
    im really interested in starting a trial with cadlab.io ... looks like we're thinking along similar lines...
    Cheers,
    Chris
    Hi Chris,
    an ULP does not have registration information accessible, but you have
    access to EAGLE's version numbers through some predefined constants.
    You'll find these constants in the HELP under "User Language" ->
    "Builtins" -> "Builtin Constants", for example:
    string s;
    sprintf(s, "%d.%d", EAGLE_VERSION, EAGLE_RELEASE);
    dlgMessageBox(s);
    dlgMessageBox(EAGLE_SIGNATURE);
    Rene
