EAGLE User Chat (English) EAGLE V8.0 Change Log
  • Views 1325 views
Other users have asked and I ran across this from the file UPDATE_en.txt.
This is obviously NOT complete since it doesn't mention the new splice
command or implicit group command.  But here is what is in the file:
Release notes for EAGLE 8.0.0
  • Licensing:
  - Update of various spots in EAGLE regarding the license changes
introduced
    by Autodesk: Standard, Premium, Ultimate, Express and Educational.
    The 30 day trial license has been removed.
  • ULPs:
  - Added 'manufacturing.ulp' provided by Autodesk. It supports an upload
of EAGLE
    drawing files to 'circuits.io' in order to generate manufacturing data
which
    can then be downloaded. The ULP is accessible as an icon in the board
editor.
  - Added 'ecadio.ulp' provided by Autodesk. It supports an upload of EAGLE
boards
    to 'ecad.io' in order to generate a 3D PCB for use in MCAD systems.
    The ULP is accessible as an icon in the board editor.
  • UI improvements:
  - Added Option.SignalNames to display the signal names on the signal
wires
    and on the connected pads and SMDs.
    It can be set in the Settings dialog under 'Misc/Display signal
names'.
  - The options Option.SignalNames, Option.PadNames and Option.ViaLength
are
    set to 'On' by default.
  • Miscellaneous:
  - Improved visibility of scrollbars for common window styles on Linux.
  - Silently ignoring double references to a contact within a signal when
loading
    a board file.
  - CAM Processor: when running 'Process Job' with more than one section,
    it is checked if the job covers the Layer Setup only partially.
  - The file locking option has been switched off by default. Use
'Backup/Locking'
    under 'Options' in Control Panel to turn it on.
  - Update of EAGLE logo to the new appearance since Autodesk acquisition.
  - Update of Hungarian translation (GUI without help and manual).
  • Bugfixes:
  - Fixed UL functions strsplit() and lookup() to handle unusual UTF8
characters
    as separator.
  - Fixed potential crash of the 64 bit versions when loading EAGLE
drawings
    from old format (e.g. V3.55).
  - Image export to TIFF format in monochrome: fixed a regression regarding
the
    compression method.
  - The selected object is no longer removed from the group after running a
ULP
    started through 'SET CONTEXT Object ...'; the ULP might want to use
this
    one-object group afterwards with e.g. 'exit("move (>@)")'.
  - Ensuring valid move of polygon wires or an entire polygon if selecting
a
    wire with 'SET CONTEXT Wire ...' or using setgroup() in a ULP.
  - Fixed history of dlgStringEdit to become case sensitive.
  - Fix for refresh of images in Control Panel preview on Windows.
  - Added a check for identical pinrefs when loading a schematic to avoid
a
    possible crash.
  - Fixed deleting/splitting busses with portrefs involved: it could happen
that
    new port connections couldn't be established anymore.
  - Fixed selecting an end of a wire with the context menu.
  - Fix for ULP function ingroup() returning true for too many objects
after
    UNDOing of transferring a group to another sheet.
http://www.stratforddigital.ca
EAGLE support forums at http://www.eaglecentral.ca :: Where the EAGLE community meets.
    autodeskguest over 9 years ago in reply to rachaelp
    On 1/24/2017 4:27 AM, Rachael wrote:
    Jorge Garcia wrote on Mon, 23 January 2017 22:22
    Hi James,
    Proper change log is forthcoming. Whole lot going on right now.
    Best Regards,
    Jorge Garcia
    Hi Jorge,
    I appreciate that a lot is going on, but really, CADSoft used to be good at
    getting a complete change log and documentation out with it's official
    releases and these are important, especially for those of us who use EAGLE
    professionally. Please can Autodesk ensure that these are done properly in
    time for being available with the actual release in future? If they are
    kept up to date with things as development is ongoing then they shouldn't
    be too hard to get done.
    Many thanks,
    Rachael
    Hi Rachael,
    Yeah, sorry about that. You'll see the situation improve over the next
    few releases as the developers get into a rythm.
    Our next update will have an appropriate changelog. Should be out in the
    coming weeks.
    Best Regards,
    Jorge Garcia
  • rachaelp
    rachaelp over 9 years ago in reply to autodeskguest
    Hi James,
    Best Regards,
    Jorge Garcia
    Hi Jorge,
    Many thanks,
    Rachael
    Hi James,
    Best Regards,
    Jorge Garcia
    • Licensing:
    introduced
    • ULPs:
    of EAGLE
    which
    editor.
    boards
    • UI improvements:
    wires
    names'.
    are
    • Miscellaneous:
    loading
       a board file.
    'Backup/Locking'
    • Bugfixes:
    characters
       as separator.
    drawings
    the
       compression method.
    ULP
    this
    a
    a
       possible crash.
    that
    after
    Hi James
    That's a copy of the statement made in the release notes of v7.7 (see
    below).
    Regards
    Warren
    Release notes for EAGLE 7.7.0
    • Licensing:
    introduced
    • ULPs:
    upload of EAGLE
    data which
    board editor.
    EAGLE boards
    • UI improvements:
    wires
         It can be set in the Settings dialog under 'Misc/Display signal names'.
    Option.ViaLength are
    • Miscellaneous:
    when loading
         a board file.
    'Backup/Locking'
    • Bugfixes:
    characters
         as separator.
    drawings
    regarding the
         compression method.
    running a ULP
    this
    selecting a
       - Added a check for identical pinrefs when loading a schematic to avoid a
         possible crash.
    happen that
    after
    ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    ... or http://www.eaglecentral.ca browser access to CadSoft EAGLE
    support forums.
