EAGLE User Chat (English) EAGLE License Recommendat ion
  • Replies 35 replies
  • Subscribers 184 subscribers
  • Views 3751 views
Hello Autodesk (specifically Matt),
In your last post about the path forward for EAGLE Make licenses, you
maintain that a "Paid" license (i.e. one that you are paying a subscription
for) will only function for 14 days without an internet connection.
I think that Autodesk has underestimated how much of an issue this will be,
especially for professional design houses.  These design houses are
important as they support, and encourage, EAGLE to be used in a
professional manner.  The recommendation from a design house to new
companies/clients go a long way to creating new customers for EAGLE (I know
Stratford Digital has influenced many companies to get an EAGLE license
because that is what we recommended, Olin has stated the same for his
company).
I think the main issue is that we professionals need our current version of
EAGLE to run forever.  But I think there is a path forward with a small
tweak.  I would love it if Matt could respond to this suggestion:
EAGLE License Recommendation
No one has an issue with requiring the internet on installation or
upgrading of EAGLE.  If a subscription is valid then either of these is
allowed.  If the subscription is not valid or can't be verified (i.e. no
internet connection) then neither is allowed BUT the software continues to
work indefinitely as it did at the time of the last call home to Autodesk
license server.
This means there is still a reason to pay subscription cost:
active support access to new features with new versions
This allows for the support that professionals will need to be able to
prove can be provided decades down the road (it happens all the time). It
allows me to create a virtual machine with a specific version of EAGLE on
it and know that in the future that software will work as it did during the
initial project development.  It also allows for use in walled-off security
environments.
We also need a method (officially supported) of having multiple versions of
EAGLE on the same computer at the same time with the ability to configure
each install to update or not automatically.  This is absolutely required
as some clients, for various reasons, specify specific versions of EAGLE to
be used.
This also puts a burden on Autodesk to make sure that their updates are
significant enough to warrant people continuing subscriptions.  That is a
good thing and will give users some confidence that a subscription is worth
it.  The value of any change since v6.6 is pretty limited, hierarchical
design is a good idea but not fully implemented.  And we're still waiting
on completion of the differential pair routing from v6.  It seems the main
additions since v6.6 is two, unasked for and highly restrictive licensing
changes.  So there isn't a lot of trust in the EAGLE community right now.
Autodesk has said good things but little has been delivered yet.
I think the above is a good compromise.  If Matt doesn't agree then please
provide your suggestion as how I am going to be guaranteed to be able to
support projects a decade in the future.  For this argument, "trusting
Autodesk will allow it" will not be accepted as an allowable answer.  It
may be 100% true today but when you leave to retire in the Bahamas or the
entire team is sold off to another global corp the policy can instantly
change (see last 6 months).
Cheers,
James
http://www.stratforddigital.ca
EAGLE support forums at http://www.eaglecentral.ca :: Where the EAGLE community meets.
    autodeskguest over 9 years ago +1
    James Morrison wrote on Mon, 23 January 2017 13:24 No one has an issue with requiring the internet on installation or upgrading of EAGLE. Almost. I have one customer where I run Eagle on a computer in…
    Former Member over 9 years ago +1
    Hi James, et. Al -- I've sent a number of variations of this email over the last few days, so let me share it and solicit people's feedback. This is some of what we're doing to make this model a bit more…
  • geralds
    geralds over 9 years ago in reply to Former Member +1
    Hi Matt, This can not be, after expiring the license period that the software will falling down to a free version. The free version is a toy for children, for playing with this at school. I have a small…
    autodeskguest over 9 years ago in reply to Former Member
    On Mon, 30 Jan 2017 21:55:00 -0800, Matt Berggren
    <technolomaniac@gmail.com> wrote:
    Firstly, from the outset we knew we've wanted to integrate EAGLE's
    capabilities with MCAD, MFG, Cutting (CAM), etc to provide something far in
    excess of any 'ECAD<>MCAD' solution on the market. After all, this is a
    deep part of Autodesk's history and the value we bring to the table, and
    the company has been centered around 3D CAD, even when done in 2D (for
    example Autocad) for 25+ years. Thus, we have been looking long and hard at
    what it takes to build 'whole products' and this acquisition of an
    electronics solution marks just the beginning of a process that'll take us
    in some wild directions. That being said, we are working on this and will
    continue, hybridizing EAGLE's schematic and PCB capabilities with an MCAD +
    MFG workflow that we hope will prove second-to-none.
    Matt,
    Has it occurred to you that there is a significant percentage of the
    Eagle user base that simply doesn't want all that complexity and cost?
    I suspect I'm close to typical.  I run a 4 person (variable number of
    contractors too) manufacturing company that manufactures induction
    heaters.  We introduced our first product, the Roy induction heater in
    2009 and that's when we bought Eagle.  I've kept it up to date until
    now.
    I do all the design work except for some mechanical work that I hire a
    contractor for.  Our needs are minimal and for that we use QCAD.  It's
    closed source but it runs on Linux and its native file format is DXF.
    To me there seems to be an obvious solution to this problem.  Keep
    Eagle as a stand-alone product just like it was and at the same time
    incorporate it into you complex and expensive product.  Backfit
    stand-alone Eagle with applicable significant new features as you
    develop them for the integrated product.
    In this manner you can service both the small user who doesn't want
    and/or can't afford the complexity of your integrated product and you
    can service your traditional customer base with the integrated
    product.
    I know that AutoDesk has gotten so large that it doesn't have to give
    a sh*t about what us small customers want.  We small companies can't
    be that way.  If a customer will pay the price, I will incorporate a
    special feature into even an old board, spin a few and modify the
    firmware accordingly.
    The design files are under source code control so I can go back and
    fetch the design files with little effort.  I keep every version of
    Eagle on our machines so it's simply a matter of firing it up and
    making the mods.
    To protect against old versions not running on an upgraded OS, I have
    a large gun safe in the building's basement.  Inside are laptops
    loaded with the environment it takes to run the old versions.  Thus if
    Canonical makes changes to Ubuntu that break old versions, I can still
    use the laptop to make the changes.
    Your current scheme of renting new versions breaks this method of
    operation.  Thus if you continue on your current path, I much change
    packages.  KiCAD is my choice.
    Understand that I don't WANT to change.  I'd like to continue in my
    current familiar work environment.  But you're currently forcing my
    hand.
    Why don't you give my proposal consideration and then adopt it?  That
    way everyone would be happy.
    John DeArmond
    http://www.neon-john.com
    http://www.tnduction.com
    Tellico Plains, Occupied TN
    See website for email address
    On Thu, 02 Feb 2017 01:41:04 +0000, James Morrison
    <james@eaglecentral.ca> wrote:
    New Proposal
    +1
    John DeArmond
  • rbeaubien
    rbeaubien over 9 years ago in reply to technolomaniac
    Matt,  This pricing does not allow for the hobbyist to continue working with Eagle.  I purchased the $169 option that allowed for 6 layers and 100x160mm boards and I designed within that limitation.  All my boards are 4 layer.  Now to get the same functionality is going to cost me $250 the first year and god know after that.  I do this for fun and don't make any money off it.  I would have no problem with a $250/subscription (every year) that also included benefits like an online parts library, but even that is a stretch, and at $500+ year, I simply can't afford it.
    Why would you change the limitations of your enthusiast versions?
  • rachaelp
    rachaelp over 9 years ago in reply to rbeaubien
    Robert Beaubien wrote on Tue, 07 February 2017 00:48
    Hi Robert, You don't need the premium subscription for 4 layer boards, they
    are upping the standard limit to 4 layers which I believe will be available
    in the next v8.0.1 release available any day now.
    Online parts library... what a horrible idea.... EAGLE already comes with a
    large part library that you can use if you absolutely must. Really though,
    everybody should just create their own clean library which they fully check
    themselves as you cannot just blindly use libraries created by others
    without thoroughly checking them first anyway. I wouldn't want Autodesk
    wasting effort creating an online parts library which is essentially of no
    real value as they should be putting their resources into useful things
    like adding more high end routing features etc.
    There isn't an enthusiast subscription version at the moment. Both the
    subscription versions are fully commercial, it's just the freeware one
    which is non-commercial.
    Best Regards,
    Rachael
  • geralds
    geralds over 9 years ago in reply to rachaelp
    Hi Rachael,
    Yes this was also my objection, when I spoke here in this forum about standards.
    Eagle v8 licensing... (look for page 10, in the middle of the page)
    (first i asked for Matt, Jorge answered me. Then we talked about the standards.)
    Then Jorge told me that AutoDesk can make the standard PCB 160 cm² with up to 4 layers.
    But! - how can I (μ) PGA or (μ) BGA? You need more than 4 layers.
    Well, this is absolutely unreal to think that "standard" is 4 levels!
    -> This "standard" was a standard in the 1990s, when we started the electronic work.
    The standard in 1985 I worked with, was 99 layers with PCAD (v 5) - on the MSDOS platform.
    Eagle did not really exist at this time. In the 90s, Eagle entered the hobby scene.
    I do not know - do you know Elektor? This was an "absolute must" in the electronics hobby in Europe.
    My first Elektor was 11/1976 - the the Layouter worked by hand with Letraset, then the layout was copied onto a thermal transfer foil.
    In the 90s to 2k's Elektor used ULTIBOARD, I used PCAD, PROTEL, OrCAD, or by hand as a training.
    Then the 2k's PCAD was migrated to Altium, the price was astronomical. So I went to Cadsoft. (v5.12)
    Elektor is now using Altium. (Why I told Elektor, because that was the beginning for most electronics engineers, they went from hobby to pro.)
    Well, what is standard ?? !! - Standard is what the market needs by giving time -> today 2017 and future.
    No, my opinion, standard for Eagle must have a full number of layers as minimum, and 1 or 2 m² dimension, not 160 cm².
    All Others is for hobby. It is a step back when you stay in a place forever.
    With 160 cm² I can not create a 19" PCB with 6U - 160x233mm.
    What is standard? - 19" or mini-PCB mounted in a brake of a car?
    What is standard? - a space ship?
    Standard was for Eagle 160x100 with 6 layers (V6).
    Now it is 160x100 with 2 layers, then "comes back" 4 layers, as mentioned above.
    Well, this is an aggressive step back! The customers are cheated, pulled over the table.
    Customers are confused with "news". In a year, no one knows any more.
    The young engineers do not know how we, the old ones, fought at that time.
    Advertising on the web is designed to be confusing.
    Has super beautiful huge pictures, but extremely little meaning.
    AutoDesk does not matter, it says: "we also provide the software for the authorities and large companies." (See a message from Matt with this sentence).
    For us it is not matter, we are dependent and have to live on both sides to get slaps (supplier side and the customer side).
    Elektor has always advertised Eagle in the magazines.
    So that in the beginning 2000? ..2005 Eagle became more popular also in the industry.
    The small contractors and private individuals reached that Eagle was also accepted by the PCB manufacturers.
    Although Eagle has not progressed in the past 10 years, especially in the last 3 years, it is used by PCB manufacturers.
    This will probably be the focus for AutoDesk.
    Just how many PCB manufacturers are there? - much less than developer offices.
    And these developers do not want to be ripped off.
    Gerald
