EAGLE User Chat (English) Eagle: Output and Supply PINS mixed on net GND
  • Subscribers 187 subscribers
  • Views 2263 views
ark262
ark262 over 9 years ago
I'm trying to power an Arduino project via AC using meanwell AC/DC supply IRM-20-12
http://ca.mouser.com/Search/ProductDetail.aspx?R=IRM-20-12virtualkey63430000virtualkey709-IRM20-12
I've taken the device from meanwell_irm_v7.lbr
When I connect the PSU to my Arduino Pro Mini, Eagle CAD is reporting Output and Supply PINS mixed. I've seen similar questions and replies indicating that the device in incorrect and should use pwr pins. I'd be surprised that the library is at v7 with this sort of error. Am I connecting it up wrong? See attached pdf (for some reason I can't attach a sch file - this is my first post)
Can someone help?
imagegroundTest.pdf
    Am 09.04.2017 um 15:52 schrieb Neon John:
    On Tue, 04 Apr 2017 00:16:43 GMT, Rob Palmer
    Can someone help?
    You can check the power supply for the correct polarity easy enough.
    finding errors in the Eagle libraries is a common event, common enough
    that I won't use a component until I've verified the pinouts from a
    data sheet or the actual part.  Once corrected, I put the part in my
    custom library, 00john.lbr.  The zeros make the library appear as the
    first one in the sort.
    John DeArmond
    http://www.neon-john.com
    http://www.tnduction.com
    Tellico Plains, Occupied TN
    See website for email address
    Apart from Neons answer: Help pin.
    Further down you find explanations about the directions on pins.
    For the ERC to work the direction of pins must be given correctly.
    Supply pins of devices (Vcc, Vdd, GND) are set as PWR because they are
    "Inputs for power".
    Devices which "give" power (like a battery) have direction SUP
    Make the directions visible by activating the layer "PINS" in *.sch.
    Joern Paschedag
    Can someone help?
    John DeArmond
