EAGLE User Chat (English) displaying attributes in layout via command line/skript/ULP
  • Subscribers 187 subscribers
  • Views 652 views
autodeskguest over 7 years ago
Hi all,
I've defined attributes on parts in the schematic editor.
Now I'm trying to show them in the layout running an ULP on the
grouped parts in the board editor or from the contex menu.
Without success so far. There seems to be no way to change attribute
visibility in the board editor, besides using the attribute dialog.
Anyone out there with an idea?
Lorenz
    autodeskguest over 7 years ago in reply to autodeskguest
    warrenbrayshaw wrote:
    On 5/11/2018 8:29 p.m., Lorenz wrote:
    Hi all,
    Hi
    You can run the CHANGE DISPLAY command
    CHANGE DISPLAY OFF | VALUE | NAME | BOTH
    So with the elements of interest grouped
    CHANGE DISPLAY VALUE (>0 0)
    CHANGE DISPLAY OFF(>0 0)
    etc.
    Hope this helps
    Warren
    yes, the "change display" command is what you need to switch the
    visibility in the end.
    But first you need to group the still not visible attribute.
    Ok, so something like the following should do:
        board(BRD)
          BRD.elements(ELM)
            if (ingroup(ELM))
              ELM.attributes(ATT)
                if (ATT.name == "AttributeName") {
                  clrgroup(BRD);
                  setgroup(ATT);
                  exit("change display value (>0 0);");
    But, it doesn't ...
    Until one remembers the famous bug where eagle (at least 6.x, which is
    what I have here) deletes the right-clicked object from the group
    before executing the exit command string.
    So, after applying the secret workaround, we get:
        if (argv[1] == "SECRETWORKAROUND") {
          board(BRD)
            BRD.elements(ELM)
              if (ELM.name == argv[2])
                ELM.attributes(ATT)
                    clrgroup(BRD);
                    setgroup(ATT);
        else {
          board(BRD)
            BRD.elements(ELM)
              if (ingroup(ELM))
                ELM.attributes(ATT)
                    exit("run thisULP SECRETWORKAROUND " + ELM.name);
                  else
                    dlgMessageBox("Attribute not found");
    we finally get what we wanted.
    Lorenz
    Hi all,
    Hi
    etc.
    Hope this helps
    Warren
    ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    This email has been checked for viruses by Avast antivirus software.
    https://www.avast.com/antivirus
