EAGLE User Chat (English) Modify footprint/mask of a component
  • Views 2773 views
  • mask
  • footprint
  • pcb components
salomonreinach
salomonreinach over 7 years ago
Hi ! I'm new to Eagle and I have to do some modifications on a PCB. I have the .brd and .sch files of a project and I made some modifications. One of the modifications I want to do is to change the cream mask of a component. I exported the library from the .sch but I still can't access to my component from the .brd, I get an error saying that it can't find the library path. So I'm wondering if anyone has an idea of how I could modify the mask and the footprint of a component knowing that I didn't create the project, I just took it from a previous work.
I also tried to edit my component in the library manager and place it in my schematic deleting the wrong one but when I switch to the board it doesn't appears and I have some errors saying that board and schematic are not consistent.
If have any ideas I take them ! Thank you for your time and your help image
  • salomonreinach
    Thank you for your answers ! I have the version 8.3.2. It works know, I started from a version without consistent errors and update the library.
    Thanks again for your help image
    autodeskguest over 7 years ago in reply to autodeskguest
    Am 12.01.2019 um 10:16 schrieb Rob Pearce:
    Which version of Eagle?
    When you replaced the component in the schematic, you did also have the
    board open at the same time, I hope. If not, that's your problem. ALWAYS
    keep both editors open together, so that the consistency is
    automatically maintained.
    First check that the original files are consistent, then make a back up
    of them!
    If you work with inconsistent files you run into trouble with lots of work.
    Then follow the advises given here before... and tell us your eagle
    version number.
    Joern Paschedag
    https://www.element14.com/community/message/270316
    If you export the library then you still need to tell it to use the new
    library. This is done under the library heading on the menu. If you want
    to use the part from the newly exported library then use the Replace
    command in the schematic.
    For the incositencies run the ERC and it will tell you what does not match.
    Doug
  • salomonreinach
    I think I have a problem between my libraries so I tried to follow that video https://www.youtube.com/watch?v=3Un_Z0kis6c to change all the components library to the same one, so it works in my schematic. When I'm selecting a component and showing its properties I have the good name of library. But when I do that on the board it doesn't work. I still have my hold name and different name of library. So I can't access to the option Open Device/Open Symbol in the board file. And of course I have an error saying that board and schematic are not consistent. Is anyone know why it doesn't also modify the library name of the component in my board file ? Whereas it change the ones in the schematics.
    Thanks image
