EAGLE User Support (English) Looking for script command to disconnect pad from pin
  • Subscribers 187 subscribers
  • Views 401 views
dukepro
dukepro over 7 years ago
Guys, I'm stumped on this one.
Eagle 7.7.0, library editor.  I'm using scripted commands to delete a
pad from a package.
In order to delete a pad from a package, I first need to delete any
device-level connections to that pad.  I can easily connect them with
the CONNECT PAD PIN ... command.  But disconnecting them seems somewhat
evasive.
Any ideas on how to disconnect a device's connections using a script
command?
    - Chuck
6318.att1.html.zip
  • dukepro
    pad from a package.
    somewhat evasive.
    command?
        - Chuck
    Update:
    I didn't find a way to delete connections, but I was able to delete the
    entire variant, then re-add it using the PACKAGE command, and re-connect
    everything (except the deleted pad) using the CONNECT command.
    With that said, I'd still like to use a script command to delete a
    single connection.
        - Chuck
    3034.att1.html.zip
