EAGLE User Support (English) Use logic device parts on different sheets
  • Subscribers 187 subscribers
  • Views 554 views
arjanver
arjanver over 6 years ago
I have a logic device which contains 4 parts ( IC1A, IC1B, IC1C, IC1D )
Now i have multiple sheets, and want IC1A on sheet1 and IC1B, IC1C, IC1D on sheet 2.
how to do that? when i cut (IC1B, IC1C, IC1D) and place in on sheet 2, IC1B, IC1C, IC1D becomes IC2B, IC2C, IC2D.
Can someone help me.
Thank you
  • dukepro
    dukepro over 6 years ago
    Delete the gates on sheet 1 that are not needed.
    Select sheet 2, and enter the command:
        INVOKE 'IC1'
    Select the gate you want to add to sheet 2, and click where you want to
    place it.
    Repeat for the other two gates.
        --- OR ---
    Right-click the gate on sheet 2 and select Invoke.
    HTH,
        - Chuck
    On 2/23/20 04:58, arjan versloot wrote:
    Thank you
    https://www.element14.com/community/message/288638
    4048.att1.html.zip
    autodeskguest over 6 years ago
    On 23/02/2020 09:58, arjan versloot wrote:
    This slightly depends which version of Eagle you have, but...
    To move a gate from one sheet to another, you need to form a group that
    includes that gate, then MOVE the group, click on the thumbnail of the
    destination sheet and place the group on there.
    This only works for group moves, not individual gates, but the group
    need only contain one gate.
    If you have already deleted the gates from sheet 1, or if you're way
    back on V4, I think, then you need a different approach. As you've
    noticed, ADD or PASTE create new instances. What you need is INVOKE, but
    since the other gate of IC1 isn't on sheet 2, you will need to use the
    command line:
          INVOKE IC1
