EAGLE User Support (English) setting a defult layer  when move is selected
  • Subscribers 186 subscribers
  • Views 457 views
  • defult layer change
sparky2017
sparky2017 over 6 years ago
Hello i am using eagle V9.3 something has changed, when in move, the default layer was the names 25  if i place a track, then go back to move i have to manually select 25
how do i fix this
thanks
Steve
    autodeskguest over 6 years ago
    move i have to manually select 25 how do i fix this
    the move command is not affected by the layer setting.
    Everything moved stays in its current the layer.
    Lorenz
