EAGLE User Support (English) system("cmd.exe /c path..."); fails if path include white space, even quoted
  • Views 1381 views
Morosh
Morosh over 6 years ago
Hello:
I made a small ulp which invoke eaglecon from inside eagle to get eps drawing, using system("cmd.exe /c path\eaglecon etc.....");
I noticed that this command fails if the path even quoted include space (in my case "C:\EAGLE-7.7.0 x32\bin\eaglecon")
I got: Windows cannot fond '-X', Make sure you typed the name correctly and then try again.
my ulp:
string cmd,fname,bname,path,path2,rot,quick;
int i;
string convert(string dumy)
string dumy2,ch;
int i;
rot="";
quick="";
dumy2="";
for(i=0;i<strlen(dumy);i++) {
   ch=strsub(dumy,i,1);
   if(ch=="/") ch="\\";
   dumy2=dumy2+ch;
return dumy2;
path=path_doc[0];
path="\""+strsub(path,0,strlen(path)-4)+"\\bin\\eaglecon"+"\"";
path=convert(path);
if(board){
   board(B){
      bname=B.name;;
      //dlgMessageBox("bname1="+bname);
      bname=convert(bname);
      //dlgMessageBox("bname2="+bname);
      fname=bname;
      fname[strlen(fname)-4]=0;
      for(i=1;i< argc; i++) {
         if(argv[i]=="rot") rot=" -r ";
         else if(argv[i]=="quick") quick=" -q+ ";
         else if(argv[i]=="sol") {
            cmd="cmd.exe /c start echo " + path + rot+quick+ " -X -f- -deps -o\""+fname+"_sol.eps\" \""+bname+"\" 16 17 18 20";
            system(cmd);
            cmd="cmd.exe /c start " + path + rot+quick+ " -X -f- -deps -o\""+fname+"_sol.eps\" \""+bname+"\" 16 17 18 20";
            system(cmd);
      //dlgMessageBox(cmd);
I've added "echo" for verification, typing the echoed string in a command window succeed.
Everything worked OK if I remove the space in "C:\EAGLE-7.7.0 x32", like "C:\EAGLE-7.7.0x32"
is there a way to resolve that?
Cet email a fait l'objet d'une analyse antivirus par AVG.
http://www.avg.com
  • Morosh
    Thanks all for reply.
    Finally it wasn't a problem of white space, I removed it and the problem persists mysteriously (although it seems to me that it works once earlier).
    So I changed my ulp and now I create a batch file, then I run it and it's working good:
    here it's if anyone is interested:
    string dumy2,ch;
    int i;
    dumy2="";
       dumy2=dumy2+ch;
    return dumy2;
    string fname,bname,path,rot,quick;
    int i;
    rot="";
    quick="";
       if(argv[i]=="quick") quick=" -q- ";
    path=path_doc[0];
    path=convert(path);
    output("toto.bat"){
       if(board){
          board(B){
             bname=B.name;;
             fname=bname;
                   printf("%s%s%s -X -f- -deps -o\"%s_sol.eps\" \"%s\" 16 17 18 20\n", path,rot,quick,fname,bname);
                else if (argv[i]=="cmp") {
                   printf("%s%s%s -X -f- -deps -o\"%s_cmp.eps\" \"%s\" 1 17 18 20\n", path,rot,quick,fname,bname);
                else if (argv[i]=="pls") {
                   printf("%s%s%s -X -f- -deps -o\"%s_pls.eps\" \"%s\" 20 22 26\n", path,rot,quick,fname,bname);
                else if (argv[i]=="plc") {
                   printf("%s%s%s -X -f- -deps -o\"%s_plc.eps\" \"%s\" 20 21 25\n", path,rot,quick,fname,bname);
                else if (argv[i]=="vls") {
                   printf("%s%s%s -X -f- -deps -o\"%s_vls.eps\" \"%s\" 20 22 28\n", path,rot,quick,fname,bname);
                else if (argv[i]=="vlc") {
                   printf("%s%s%s -X -f- -deps -o\"%s_vlc.eps\" \"%s\" 20 21 27\n", path,rot,quick,fname,bname);
                }  //for(i=1;i< argc; i++)
                printf("del toto.bat\n");
             }  //board(B){
          }  //if(board)
       }  //output("toto.bat")
    system("cmd.exe /c toto.bat");
    I'm using this way also to generate gerber files, I found it's more comfortable than cam processor
    Regards
    autodeskguest over 6 years ago in reply to dukepro
    On 10/11/2020 14:19, Chuck Huber wrote:
    2. Try preceding each space in /path/ with a backslash:
    I believe that would fix his problem on Mac or Linux but not on Windoze,
    where backslash is the path separator rather than an escape character.
    I'm sure the OP won't accept this answer but the easiest fix is to never
    use space characters in path names. They are evil for many reasons, this
    being one of them.
    More usefully, I will point out that this is NOT an Eagle issue but
    rather a Windows shell problem. See:
    https://stackoverflow.com/questions/6376113/how-do-i-use-spaces-in-the-command-prompt
    https://superuser.com/questions/432980/how-to-call-a-program-that-contains-space-in-filename
    https://superuser.com/questions/239565/can-i-use-the-start-command-with-spaces-in-the-path
    https://superuser.com/questions/1478512/how-do-i-pass-a-filename-with-spaces-from-wsl-to-cmd-exe
  • dukepro
    dukepro over 6 years ago
    Morosh,
    1. In everything you do, do it do the best of your ability.
    1a. Add prolific comments, especially when presenting code to colleagues.
    1b. Use proper indents.  4 spaces for each indent level.
    See below.
    Best regards,
        - Chuck
    On 11/10/20 02:58, Morosh wrote:
    Hello:
    my ulp:
    int i;
    string dumy2,ch;
    int i;
    rot="";
    quick="";
    dumy2="";
       if(ch=="/") ch="
    *    if (ch==" ") ch="
       dumy2=dumy2+ch;
    return dumy2;
    path=path_doc[0];
    path="\""strsub(path,0,strlen(path)-4)"
    bin
    eaglecon"+"\"";
    path=convert(path);
    if(board){
       board(B){
          bname=B.name;;
          fname=bname;
                cmd="cmd.exe /c start echo " + path + rotquick " -X -f- -deps -o\""fname"_sol.eps\" \""bname"\" 16 17 18 20";
                system(cmd);
                cmd="cmd.exe /c start " + path + rotquick " -X -f- -deps -o\""fname"_sol.eps\" \""bname"\" 16 17 18 20";
                system(cmd);
    2742.att1.html.zip
