EAGLE User Support (English) Re: system("cmd.exe /c path..."); fails if path include white space, even quoted
  • Subscribers 187 subscribers
  • Views 643 views
autodeskguest over 6 years ago
Am 09.11.2020 um 18:19 schrieb user@domain.invalid:
Hello:
I made a small ulp which invoke eaglecon from inside eagle to get eps
drawing, using system("cmd.exe /c path\eaglecon etc.....");
I noticed that this command fails if the path even quoted include space
(in my case "C:\EAGLE-7.7.0 x32\bin\eaglecon")
I got: Windows cannot fond '-X', Make sure you typed the name correctly
and then try again.
my ulp:
string cmd,fname,bname,path,path2,rot,quick;
int i;
string convert(string dumy)
string dumy2,ch;
int i;
rot="";
quick="";
dumy2="";
for(i=0;i<strlen(dumy);i++) {
   ch=strsub(dumy,i,1);
   if(ch=="/") ch="
   dumy2=dumy2+ch;
return dumy2;
path=path_doc[0];
path="\""strsub(path,0,strlen(path)-4)"
bin
eaglecon"+"\"";
path=convert(path);
if(board){
   board(B){
      bname=B.name;;
      //dlgMessageBox("bname1="+bname);
      bname=convert(bname);
      //dlgMessageBox("bname2="+bname);
      fname=bname;
      fname[strlen(fname)-4]=0;
      for(i=1;i< argc; i++) {
         if(argv[i]=="rot") rot=" -r ";
         else if(argv[i]=="quick") quick=" -q+ ";
         else if(argv[i]=="sol") {
            cmd="cmd.exe /c start echo " + path + rotquick " -X -f-
-deps -o\""fname"_sol.eps\" \""bname"\" 16 17 18 20";
            system(cmd);
            cmd="cmd.exe /c start " + path + rotquick " -X -f- -deps
            system(cmd);
      //dlgMessageBox(cmd);
I've added "echo" for verification, typing the echoed string in a
command window succeed.
Everything worked OK if I remove the space in "C:\EAGLE-7.7.0 x32", like
"C:\EAGLE-7.7.0x32"
is there a way to resolve that?
Looks like you use windows. Unfortunately you didn't tell which version.
In newer versions of windows there are user "groups", means that your
path could be something like
C:\USER (your name)\eagle etc.
Check that out first, then check if you can reach your program  via CMD,
to verify that the complete path is correct.
Joern Paschedag
  • Morosh
    Morosh over 6 years ago
    Thanks for reply.
    yes I was using W10-x64
    Finally it wasn't a problem of white space, I removed it and the problem persists mysteriously (although it seems to me that it works once earlier).
    So I changed my ulp and now I create a batch file, then I run it and it's working good:
    here it's if anyone is interested:
    string dumy2,ch;
    int i;
    dumy2="";
       if(ch=="/") ch="\\";
       dumy2=dumy2+ch;
    return dumy2;
    string fname,bname,path,rot,quick;
    int i;
    rot="";
    quick="";
       if(argv[i]=="quick") quick=" -q- ";
    path=path_doc[0];
    path="\""+strsub(path,0,strlen(path)-4)+"\\bin\\eaglecon"+"\"";
    path=convert(path);
    output("toto.bat"){
       if(board){
          board(B){
             bname=B.name;;
             fname=bname;
                   printf("%s%s%s -X -f- -deps -o\"%s_sol.eps\" \"%s\" 16 17 18 20\n", path,rot,quick,fname,bname);
                else if (argv[i]=="cmp") {
                   printf("%s%s%s -X -f- -deps -o\"%s_cmp.eps\" \"%s\" 1 17 18 20\n", path,rot,quick,fname,bname);
                else if (argv[i]=="pls") {
                   printf("%s%s%s -X -f- -deps -o\"%s_pls.eps\" \"%s\" 20 22 26\n", path,rot,quick,fname,bname);
                else if (argv[i]=="plc") {
                   printf("%s%s%s -X -f- -deps -o\"%s_plc.eps\" \"%s\" 20 21 25\n", path,rot,quick,fname,bname);
                else if (argv[i]=="vls") {
                   printf("%s%s%s -X -f- -deps -o\"%s_vls.eps\" \"%s\" 20 22 28\n", path,rot,quick,fname,bname);
                else if (argv[i]=="vlc") {
                   printf("%s%s%s -X -f- -deps -o\"%s_vlc.eps\" \"%s\" 20 21 27\n", path,rot,quick,fname,bname);
                }  //for(i=1;i< argc; i++)
                printf("del toto.bat\n");
             }  //board(B){
          }  //if(board)
       }  //output("toto.bat")
    system("cmd.exe /c toto.bat");
    I'm using this way also to generate gerber files, I found it's more comfortable than cam processor
    Regards
