EAGLE User Support (English) "Save selection as design block broken"
  • Subscribers 187 subscribers
  • Views 1830 views
smashcat
smashcat over 5 years ago
Has this option ever worked? I've become used to just creating a copy of the whole design, then removing parts I don't need, then saving the rest as the design block. The "Save selection..." option for design blocks does absolutely nothing. No status text, no popups, just nothing happens, or it locks up something in Eagle, so the selections are then broken for everything until I restart Eagle (i.e. the select tool no longer works at all ).
It would be a nice feature to have for sure.
  • smashcat
    smashcat over 5 years ago in reply to autodeskguest
    No, I need to create design blocks. Full designs can't be included in other designs. But modules can. the version of Eagle I'm currently using is 9.6.2 (FULL)
    Scott
    autodeskguest over 5 years ago
    Am 24.05.2021 um 02:42 schrieb Scott Porter:
    https://www.element14.com/community/message/302585
    Please if you want a correct answer always tell us your Eagle
    VERSION.
    If this function is not doing what you want, why not saving it as a
    "new" design with an appropriate name. Plenty designs repeat in other
    applications, so I use those as basic designs and integrate them with
    modifications.
    Joern Paschedag
